![]() | Home > Puma (Tdci) > Ignition lock issues |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3354 ![]() ![]() ![]() |
Are you sure it's not the steering lock? Give the wheel a wiggle. WARNING.
This post may contain sarcasm. |
markespark Member Since: 20 Sep 2012 Location: Huntingdon Posts: 85 ![]() ![]() |
I have been 😩
It feels like barrel has collapsed
Are you sure you have the correct vehicle?
![]() Seriously though, the wife had this on her my15 dcpu and with a good firm tug and hold of the wheel while putting the key in got it going. I seem to remember she was parked on a slope at the time on full lock and couldn’t get it to turn. Brute force won ![]() My build thread http://www.defender2.net/forum/topic17615.html |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8201 ![]() ![]() ![]() |
if the worst comes its about £60 for a new ignition barrel with switch and an hours work Cheers
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 391 ![]() ![]() ![]() |
Had the same issue on my 2015 Puma. Intermittently it won’t turn. Purchased a new OEM assembly and will fit at some point. Naturally the lock has been perfect since I ordered the replacement part
Bill1919 Member Since: 04 Mar 2017 Location: Dorset Posts: 59 ![]() ![]() ![]() |
Yes it's quite common. After sometimes spending 5 mins jiggling the key I replaced mine at around 30,000 on my 2015 puma. Had same issue with a tdi 300 about 20 years ago, so not improved.
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Mine was replaced under warranty at around two years old and only perhaps 10,000 miles. The LR service manager couldn't get it to turn when I took it for its service!
It all seems to depend on the consistency of the cheese which they made them from on any given day.... |
It’s been ok today 🙄
My worry is that I’ll get stuck again 🤔 |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 199 ![]() ![]() |
Mine did this on 4 separate occasions (All at less than 3000 miles old) - ended up being sorted under warranty and they changed the locks. Managed to damage the steering column in doing so somehow, so that was replaced and then they damaged the indicator stalk. Quality LR dealership....
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Worth trying a little graphite powder on your key. Might just free up the internals.
Did mine a couple of years ago when it got sticky, and still ok now. |
