![]() | Home > Technical > Hi Cap, heavy Duty Spec |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 ![]() ![]() ![]() |
i think its an extra smaller spring inside the main spring
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Yep... from what I thought was that it is standard..... what would be the point of a Hi-cap with a low weight carrying ability? Unless you are transporting feathers maybe. Glyn ![]() ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
HiCaps didn't have the double springs (AKA 130 springs) as standard, unless you chose the HD option.
If you wore green for a living, the HD option would also include a salisbury front axle! I've got the 130 springs on the back of my 110 SW. As SC70 says, it's a smaller spring inside the main spring, with a cap on the top (sits under the chassis spring mount) and a bit that bolts onto the lower spring mount, which locate this smaller spring in place, so if you were thinking about it, you couldn't have drop out springs and relocation cones. |
