Home > General & Technical (L663) > Domestic socket rating |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3372 |
Does it not state on the plug socket how many watts it is? The image from the brochure shows something but it is obscured by the actual plug.
7th Sep 2020 3:31pm |
G4R1 Member Since: 17 Aug 2020 Location: Barnet/Limassol Posts: 131 |
I believe it’s only 180w rated. Im not sure if its suitable for charging gadgets.
7th Sep 2020 3:34pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
180W 110-240V
I believe it's a pure sine wave converter too so it should be good for laptops, cameras... One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
7th Sep 2020 3:46pm |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Looks like new glasses are needed
Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
7th Sep 2020 6:19pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
Unusual, but definitely an advantage if it is. |
7th Sep 2020 7:11pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1316 |
It seems a strange place to locate the plug socket. So low down, especially when, as per Tim's photo, a load mat will further reduce the clearance below the socket. Does that small section of the load mat lift out Tim to access the tie down loop?
Apart from the difficulty in plugging in many adaptors and even standard UK style plugs with moulded downward facing cable supports, it looks quite vulnerable to getting knocked by moving luggage or being soaked from wet gear or dogs. And presumably, with anything plugged in it will prevent large items of luggage from being placed flush against the side of the load bay area.I would have thought placing it higher up, or on the rear trim panel somewhere would make more sense, but perhaps I am just being picky. |
7th Sep 2020 7:45pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3497 |
0.78 Amps (180 Watts divided by 230 Volts) so not a lot. but enough for gadget charging
If LR start selling a Kettle to plug in to that socket, it might take all week to boil |
7th Sep 2020 8:43pm |
Lohr500 - the mat has numerous cut out lines, but for the money you pay LR expects you, the customer, to take a craft knife to them to cut them out......I have never needed the tie down rings in any of my cars so don’t bother to cut them to shape and I suspect many owners are the same. It was the same with my L322’s, Evoque’s and RRS’s and they were so mean that when I went from L320RRS to L494 RRS they moved the tie downs a little and moved the wheel arches so my old L320 rubber mat wouldn’t fit. and I had to buy a new one. The old ones sell well on the used market/ forum For Sale section!
Strangely my Evoque boot mat fitted perfectly in the Mini Countryman’s boot, even the lashing ring cut outs were just about in the same places so I didn’t need to spend money on a BMW boot mat! BTW I would suggest the the L663 Defender mat is essential, not to stop damage to the fake chequer plate floor but because it is so darned slippery that anything in the boot not secured just slides around on every bend or hill. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
7th Sep 2020 9:48pm |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1031 |
All they had to do was turn the socket around 90 degrees. Even a plug with a cable protector would be a pain to plug in to that.
8th Sep 2020 7:20am |
This won’t fit in it as it’s what I tried on Sunday - even with the mat removed it wouldn’t plug in fully. It’s the charger for my Fuji X-20 camera that takes a mobile phone type battery. I cannot charge the battery while it’s in the camera via a USB connection
Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! Last edited by Tim in Scotland on 8th Sep 2020 7:36am. Edited 2 times in total |
8th Sep 2020 7:30am |
Is that a tie-down point completely obscured by the USB adaptor? It looks very like another 'own goal' to me, a great idea completely devalued by crass implementation! |
8th Sep 2020 7:31am |
That charger from the brochure is not a U.K. plug type it’s Euro 2 pin by the look of it and yes that’s a tie down point right below the socket. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
8th Sep 2020 7:37am |
Vin60 Member Since: 29 Dec 2020 Location: Moscow Posts: 10 |
Anyone considered possibility to update to more powerful inverter? LR099090 inverter, which JLR uses in RR, RRS and DEF is too weak to charge laptop, like shown on brochure picture since its requires 1,5A
24th Aug 2021 6:57pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2751 |
180W should be more than enough to charge a laptop? Even a beefy MacBook Pro can only take 60 odd watts from memory.
The sub-1 amp rating at 230V is kind of irrelevant when the laptop/device charger will step down to 12 or 5 volts anyway? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
24th Aug 2021 9:55pm |
