![]() | Home > Technical > Sidelights blown |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1044 ![]() ![]() ![]() |
Just back from a trip to Orkney and noticed both sidelights have failed. Headlights and rear tail lights working fine.
Before I order new bulbs, could this just be a blown fuse? Just a coincidence or underlying problem? Could be an opportunity to upgrade to LEDs - if so, would love some recommendations of just a straight bulb swap - I don't fancy mucking about and want to keep the original look. It's a 2015 2.2 110 SW. Thanks |
All the warning lights work, so I guess it's not the fuse.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6645 ![]() ![]() ![]() |
They are fused Left and Right rather than front and back, so won't be a fuse issue.
The front lamps do share a common earth, but this is also shared with the headlights so they wouldn't be working either. Likely to just be a pair of blown bulbs. ![]() ![]() |
