![]() | Home > Puma (Tdci) > 2.4 issues |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1232 ![]() ![]() |
Hi
Not much help to you but last year at the end of a 300 mile run I had exactly the same. Re set the code and it has been running fine ever since. 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1960 ![]() ![]() ![]() |
Re the brake light, check the reservoir is just above the max line
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
Reference the brake light, have a read of my post here https://www.defender2.net/forum/topic55679-9.html
and reference the fault code, have a look at my post here https://www.defender2.net/forum/topic53240-113.html Good luck ![]() |
Primaryroo Member Since: 15 Aug 2020 Location: kent Posts: 21 ![]() ![]() ![]() |
Thanks for the replies, will check all tomorrow. Thanks again series 2a 1966
defender 90 1991 discovery 3 2005 discovery 2 2003 defender puma 110 2008 defender puma ex scottish power 2.4 2011 |
