Home > Td5 > transmission vibration
cherob1boats
Hi everyone, another question. I get a vibration and rumble about 52 mph and on. it sounds like its coming from the drive train some where. My question is this. can I remove front propshaft and drive the defender. Then refit it and remove the rear one and again drive it. is this a way of proving propshaft inbalance? Can any damage be done driving with one propshaft? Thanks
Post #853165 30th Aug 2020 8:05pm
As long as you don't go mad, you'll be fine to remove each prop-shaft in turn and, with the diff-lock engaged, be able to drive it on just the one remaining. Darren
Post #853167 30th Aug 2020 8:10pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Short answer is yes. No problems. As above ☝🏻 Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #853177 30th Aug 2020 8:30pm
Don't forget that with the rear prop removed you'll have no handbrake unless the centre diff lock is engaged.
Post #853185 30th Aug 2020 8:40pm
roel
Make sure your handbrake drum is tight. If it comes off it can do damage.
If you do the rear propshaft test do it with the handbrake drum on and off. The handbrake drum can cause vibration too. Roel
2003 90 Td5 (2009-now)
Post #853189 30th Aug 2020 8:49pm
4RF RDS
It’ll be u joints, just grease the Censored out Of em!!!! Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #853260 31st Aug 2020 4:36am
I needed a couple of washers on each bolt too on the handbrake drum before the nut as with not having the Prop in place the nut would have hit the non threaded shank of the bolt. So some washers on each bolt solved that issue.
IIRC they are an imperial size, sadly I can’t remember off the top of my head what it is.
Personally I would then torque those nuts up exactly the same as if the prop was in place.
And as mentioned you need the diff lock engaged to and the handbrake drum in place at all times.
Go easy and treat it as a very temporary measure. I think I only went 10 days or so when I did mine, they handle differently too. WeWillWin🇬🇧🇺🇸
Post #853341 31st Aug 2020 1:30pm
custom90steve wrote:
... they are an imperial size, sadly I can’t remember off the top of my head what it is. ...
I'm pretty sure you'll find they are 3/8" UNF (which takes a 9/16" AF spanner/socket size).
Post #853388 31st Aug 2020 6:00pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Correct. Here’s one one of mine that’s stays in the defender at all times.
 2002 td5 90 county hardtop
Post #853407 31st Aug 2020 7:37pm
miker
I did the same to try and identify which axle/diff had all the slop in it. Turns out it was both (and probably the centre one to boot)
Post #853413 31st Aug 2020 8:11pm
