![]() | Home > In Car Electronics > Heated front screen wiring HELP |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
I would think the white/green from the heated rear window switch would be suitable if you only need an ignition live for the switch and relay. The radio switched live is also live in key position I which isnt really right for the heated screen.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
G-P Member Since: 27 Oct 2019 Location: Cambridge Posts: 16 ![]() ![]() ![]() |
That makes sense, no issue with using the same switch for the red/orange and black wires as well?
What’s the best way to check the heated screen is actually working correctly? Volt meter in the window connections? Thanks |
No cant see any issue with taking all of the switch feeds you need from the HRW switch as long as they are only feeding the heated screen switch and relay.
To test, as you say, multimeter over the terminals at the screen to check you have voltage. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Thanks for your help, all up and running now. I managed to put the dash back with no leftover screws as well.
