Home > Maintenance & Modifications > 2006 defender safari door leaking at top |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 618 |
It is the weight of the spare wheel flexing the door away from the seal.
26th Aug 2020 9:22pm |
Nige71 Member Since: 05 Jun 2017 Location: bristol Posts: 38 |
Thanks i thought it might be the spare wheel , wish were seal as i like the look of spare on back.
27th Aug 2020 5:48pm |
cee-b Member Since: 25 Jan 2018 Location: South West Posts: 117 |
Maybe consider fitting a swing away wheel carrier? (Mantec or similar). The weight of the wheel will eventually do damage to your door and hinges if it is left on there.
28th Aug 2020 6:53pm |
Yes thanks there is that , i went to local fibre glass maker to make mock wheel to put cover over but wanted £200 to make OUCH . Nige
29th Aug 2020 8:33am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 729 |
Have you checked your hinges for play? May be a worn hinge causing alignment trouble.
If all ok the simple solution might be to try a new door seal, but would recommend a LR seal, not aftermarket. This keeps it as is, which you say you prefer. |
29th Aug 2020 9:40am |
Thanks for the info have checked no play in hinges will try and source genuine new seal and hope it works . thanks
29th Aug 2020 7:44pm |
