![]() | Home > Puma (Tdci) > Central Locking |
Almost certainly broken wires in the rubber tube between door and B post.
The button disappearing suggests that the linkage has come adrift inside, possibly due to forcing against the central locking actuator. Take the door card and water shedder off and I'm sure all will be clear. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The wires in the rubber boot from b post to doors will have snapped it’s a very common fault that can be fixed with some better quality wire and a bit of soldering. If the buttons have dropped down the plastic pin holding the pivot to the door frame may have broken. Should all be clear if you take the door card off.
Edit: beaten to it ![]() My build thread http://www.defender2.net/forum/topic17615.html |
sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148 ![]() ![]() |
Thanks .Do I need to buy any parts ?
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 186 ![]() ![]() ![]() |
One of my rear doors has stopped working on the central locking. Now it's stopped raining, I'll take a look at the wiring. Thanks for the help gents.
Cheers Chris |
