Home > Td5 > Intermittent rear wiper gizmo |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6612 |
Watch and weep
Connections-wise, it is as follows:
Martin 1988 90 Td5 NAS soft top 2015 D90 XS SW |
26th Aug 2020 11:01am |
Thanks, Martin. Can't view it at work, unfortunately but will take a look later. Darren
26th Aug 2020 11:56am |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 |
Mine is 2001 Y reg TD5 90. I fitted a VW 99 relay for the front wipers and the relay I pulled to fit the 99 I swapped with the relay that "feeds" the rear wiper. Both my relays are in the front cab near the gear stick. The rear wiper now runs as the front did when it was set to "intermittent", about every 6 seconds, still a bit quick but better than on all the time. Mike
Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
27th Aug 2020 4:53am |
