Home > In Car Electronics > OEM Alpine Subwoofer Wiring
Page 3 of 5 <12345>
dgardel
Italy
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #851699 24th Aug 2020 2:21pm
Tomaco1
United States 1983 Defender 110 200 Tdi DCPU Caledonian Blue
Martin wrote:
I do a loom for the LR version of the sub Whistle
I know what I need, 4 foot leads(122cm), female rca’s, no fuse Or connectors.
Just let me know how to proceed
Thanks
Post #852005 25th Aug 2020 9:06pm
Martin
Site Admin
PM sent Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #852094 26th Aug 2020 10:30am
Ihod
United Kingdom 1998 Defender 90 300 Tdi ST Rioja Red
For those considering a retrofit of the OEM sub and who, like me, don’t have the benefit of the factory loom present when they remove the cubby box, Martin does provide a beautifully constructed loom at a very modest cost which does in quick time what I have failed to achieve over a number of spoiled and sweary weekends.
So highly recommended and very many thanks, Martin. Ian
MY1998 300Tdi 90 Hard Top (Now Soft Top)
MY2015 110 XS SW - Sold
MY2008 110 County USW - Sold
MY1962 Series IIa Truck Cab - Sold
MY1994 300Tdi 90 Hard Top - Sold
MY2001 TD5 90 Truck Cab - Sold
Post #856403 17th Sep 2020 12:30am
Tomaco1
Mine also worked perfectly
Post #856404 17th Sep 2020 1:23am
hugh.
2014 Defender 110 Puma 2.2 SW Corris Grey
To clarify, if I check underneath the cubby box of my 2014 and it has a plug it should be plug and play with the sub linked below?
If I dont have the plug under the cubby I need to order the loom from Martin? Is it still essentially plug and play then?
https://www.lrmotors.co.uk/store/product/a...2-18808-ca
Post #894518 28th Mar 2021 5:22pm
hugh.
Post #894519 28th Mar 2021 5:22pm
Co1
Not necessarily Hugh. You will probably have to connect the other end of that plug which sits behinds the head unit. If it’s like mine it was just wrapped up out of the way. You may need to get an adaptor loom to go from that to the head unit. Martin sells them for not a lot of cash.
Post #894528 28th Mar 2021 6:13pm
hugh.
Perfect. I'll have a look this evening
Post #894529 28th Mar 2021 6:16pm
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Mine had the wiring all there but when I hooked it all up it still wasn’t working. Couldn’t figure it out so took it to local autoelectrics place figured out it needed separate power to the sub. https://instagram.com/bentheoandrews
Post #894548 28th Mar 2021 7:27pm
Martin
Site Admin
If the factory plug is present for the sub under the cubby you will still need the short adapter lead from RCA (phono) x2 to the small grey plug behind the radio - LR040847 - these are not cheap though! (£40+VAT). Although I have made these up in the past.
Also check for presence of fuse 21P under the steering wheel.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #894675 29th Mar 2021 2:13pm
leonvh
Belgium 2013 Defender 110 Puma 2.2 SW Barolo Black
My 2013 Defender came with the factory subwoofer. From almost new I switched to an Alpine flip-out head-unit. All worked fine on that. From what I remember I just connected the 2 RCA's behind the head-unit for audio and nothing else. Used the Mudstuff ISO adapter for all other wiring.
Recently I changed to a new head-unit, but I cannot get the subwoofer to work. The only difference is that the head-unit has only a single subwoofer RCA output, so I bought and fitted a Y-adapter. But still no sound from the subwoofer.
From the plug at the subwoofer I do measure 12v. Does anyone have an idea what I'm missing here? Does the subwoofer need a 'wake-up' signal just like amplifiers? Does it maybe have a fuse inside the unit that I might have broken with my tinkering?
Would appreciate any help here. Next step would be to get Martin's loom to bypass all existing wiring, but his shop is still closed.
Post #947251 28th Mar 2022 7:37am
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Sorry for digging this from the depths folks.....
Struggling to source the wiring harness to fit the 'take out' OEM Alpine sub I have bought - any ideas most welcome! Rgds.
Chris
Post #953108 21st May 2022 5:28pm
Pacha
Martin has been in touch via PM - happy days! Rgds.
Chris
Post #953249 22nd May 2022 10:14pm
edward
power to factory sub when you have the plug under cubby
Hi. So I’ve been though all the threads I can find on this subject but I’m still slightly confused. Hopefully someone can give me the definitive answer (and sorry if this is really stupid)
I have a 2013 puma and the factory head unit. I’ve bought the factory sub (with built in amp and one cable) and I have the sub loom under the cubby box. I have ordered the rca to loom cable that will fit from the head unit to the plug behind the dash.
Will this be enough to get the sub working? Or will I still need to power the sub / amp and if so how do I do it? Do I need to do something to the single grey plug on the sub? Has anyone done this they can post pictures?
Many many thanks Ed.
Post #977092 8th Jan 2023 2:04pm
Page 3 of 5 <12345>
