Home > Puma (Tdci) > Computer Connectors |
nikojo Member Since: 05 Aug 2011 Location: Madrid Posts: 75 |
How do you unclip the computer connectors??
There are three connectors on the side of the ECM at the bulkhead. There are three white clips that look like they rotate down. I've put quite a bit of pressure on it but don't want to break it. Any tips?? |
18th Aug 2011 7:45pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
I just read your post again I jamp the gun a it there OK, the connectors should just leaver and force the pug off, but you will probably have to help them off- the plastic clip thing won't be strong enough to break the watertight seal between the plug and ECU. If that makes sense? once you have levered as far as you can go pop a large flat blade screwdriver between the plug and ECU and work them both together- that should pop them off.
But as always, if it feels like it is going to break/ snap, stop as it probably will. Glyn |
19th Aug 2011 6:32am |
