![]() | Home > Tdi > Clutch Pedal - Can someone explain? |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
IIRC the release bearing shouldn't actually touch the pressure plate when the pedal is 'up'.
Therefore any noise is either the centre plate / pressure plate or more likely something loose nearby, a heat shield, loose bolt, exhaust etc. Only really way will be up on a ramp with it running and listening carefully. HTH Keith |
zippo87 Member Since: 29 Mar 2019 Location: Moray Posts: 100 ![]() ![]() ![]() |
I have always had a little rattle on idle clutch up when cold, goes when pressed, and once warm. The original never got any worse even after it destroyed itself, and same with the LOF I have now - it doesn’t answer your question I appreciate, but I did my own replacement and hoped I’d sort it at the same time and came up Stumped - it is something I can live with. I didn’t even consider height of the pedal 😂 but I do have short legs!!
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8172 ![]() ![]() ![]() |
Sounds like the release bearing contacting the pressure plate, or faulty clutch plate, which is very unlikely.
Adjusting the pedal position doesnt/shouldn't be used to, preload the clutch/bearing. New bearing too? It may resolve with time. Quite a few tdis and tdcis rattle neutral tickover clutch disengaged. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 ![]() ![]() |
Was the clutch fork replaced when you had the pressure plates done? The cup that holds the actuation rod does have a habit of wearing over time WHAT COULD POSSIBLY GO WRONG
My sky lantern petition http://chng.it/HJXmZC47 |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2285 ![]() ![]() ![]() |
Gear chatter is common and often noisier after new clutch which has new strong springs. They soften over time and the effect is reduced.
