Home > Td5 > Will it crank on ignition when immobilizer is engaged?
Defendertomten
Sweden 2000 Defender 130 Td5 HCPU Coniston Green
I have forgotten whether it does or not.
Apparently my does not. But starts and runs 1.8 sec on bypass.
Then I can exclude the earthing problem. Land Rover owner since 2003
2008 Disco3 manual
2000 Defender 130 td5 snorkel warn m6000
Post #851121 20th Aug 2020 12:54pm
dorsetsmith
Will not crank on ignition when immobilizer is engaged
Post #851135 20th Aug 2020 2:23pm
Martin
Site Admin
An immobilised Td5 ECU, if you bypass the starter relay lock out from the 10AS, will run for a second or two before turning off the engine.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #851137 20th Aug 2020 2:59pm
Defendertomten
Thanks a lot. Then its only lock out from the immobilizer probably.
i made a mistake and had the key with the keyfob in ignition and what ive heared is that
it can disturb the as10 because its not in the system due to empty battery earlier or failed ignition lock coil.
But there’s also a kick out time if the eka code is set wrong ive also read. But cant remember how long. Land Rover owner since 2003
2008 Disco3 manual
Post #851231 21st Aug 2020 7:03am
Martin
Site Admin
What is the red alarm LED in the speedo doing?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #851237 21st Aug 2020 7:47am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
if the 10AS is immob, it will not crank.
if the ECU is immob and the 10AS is not, it will crank.
this can happen when you try something funny like swapping around ecu and 10as unit, due to the security code and you will now need the 10as to learn the ecu code again. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #851281 21st Aug 2020 12:54pm
Defendertomten
It flashes every second Land Rover owner since 2003
2008 Disco3 manual
Post #851283 21st Aug 2020 1:08pm
Defendertomten
And when i disable with the remote the red flash disappears. But no cranking. And start and stop using bypass on the starter relay Land Rover owner since 2003
2008 Disco3 manual
Post #851285 21st Aug 2020 1:17pm
dorsetsmith
Is fuse one passenger fuse box ok alarm ignition 12v input from ignition switch
is starter relay passenger fuse box left hand side relay (yellow) clinking then you go to start the engine with the key with immobiliser ds-engaged
12 volt + input from ignition switch to starter relay and ground from alarm unit
Post #851288 21st Aug 2020 1:57pm
Defendertomten
I pulled the upper right fuse and then it went beep beep and the
over crossed engine came🤪. Havent had it before this time. Then i tried with the eka code as every time before. Did not
work. Then i tried alarm off on my key fob.
It worked!!!! No overcrossed engine no flasing red led👌🏻😁
It cranks. But then battery was too empty too start. But now its going to run im quite sure.
Thank you very much for the help!
I thought i had earth gremlins everywhere.
Now is ”only” cut the rest of the rear crossmember and weld on the new. And maybe get fbh running.
My defender will save my ass this winter when christmas tree disco3 needs overhaul ( crazy hand brake, lousy front brakes, no ac, half running fbh, engine light due to egr, time to change timing belt etc) Land Rover owner since 2003
2008 Disco3 manual
Post #851293 21st Aug 2020 2:52pm
Martin
Site Admin
Well done Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #851296 21st Aug 2020 3:16pm
Defendertomten
Must have been some interference between as10 and ecu? Or not really contact in the fuse?
Quite strange. Or did i trig the as10 when i pulled the fuse?[/i] Land Rover owner since 2003
2008 Disco3 manual
Post #851298 21st Aug 2020 3:18pm
dorsetsmith
If alarm ignition 12 v input from ignition switch not work the alarm will not provide ground to the starter relay, may be fuse holder corroded and when you removed fuse and replaced it remade contacted
Post #851305 21st Aug 2020 3:34pm
