![]() | Home > Technical > Air con fan |
With the air con fan being on the front of the radiator should it pull air into the radiator (Towards the back of the car) Or away (to the front of the car) from the radiator?
Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
Into the engine bay
So pushing the air through the air con rad and water rad? That’s what I thought it should be. Must have wired it back to front
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Top hose temperature.
When you key off the water pump stops with the engine. That means that the radiator top hose gets very much hotter than it normally would due to the circulation having stopped but the heat still soaking out of the engine block into the coolant. Most cars have run-on functionality whereby they'll monitor the top hose temperature (or work it out by algorithm based on atmospheric temp plus block temp) and run the fans on once you've keyed off to avoid the top hose from experiencing such high temperatures. The complexity in that is when you've got a thermoviscous fan not a "normal car" approach of having electric fans that do both condenser pack and the main radiator. I.e. a defender. On a defender to do the same thing the only tool available would be the air conditioning condenser fan which would push air through the rad pack, albeit rather inefficiently due to the relative heights and the air gap between them. Not had mine do it... Even in very hot weather and towing. .....so having spouted all that, it could we'll not have that functionality and actually just be a different issue! |
I’ll switch the wires around on the fan and see if it cools better and maybe only kicks in for a while. Thanks for the reply’s
