Home > Maintenance & Modifications > Doorcard disappointment. |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1841 |
I have done this in a couple of places.
Front doors - on the corners which use the larger plastic clips; and on one of the 2nd row doors, at the bottom. However I had to take that door card off again to fix a loose handle, and I found myself thinking exactly the same thing as you. The allen/socket head screws are so easy to use; the clips are not! As far as I can see the problem will be those places on the door card which are much thicker, and where the bolt would have to come in through the 'side' of the card. I think you'd have to drill a hole, but also dig out a 'flat' for the bolt head or washer to sit against. One day if I have the time I might do more. I'd also be interested to see if anyone else has taken this further. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
17th Aug 2020 9:26am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17365 |
Use a piloted counterbore cutter to counterbore the hole to accept the screw-head. Google "piloted counterbore cutter" for more information. |
17th Aug 2020 10:09am |
