Home > General & Technical (L663) > 2020 Defender main discussion thread
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 261 of 351 <123 ... 260261262 ... 349350351>
Smilesapart
Telemarkskier wrote:
That's one thing I wanted that I felt was missing in the New Defender. Moving from a Freelander 2, the gear selector in the Defender works in the opposite way! That will require practice to avoid mistakes and become second nature without having to think in advance.
Well our other car IS a Freelander 2 that we will be running along side it. So we shall have to be careful it doesn’t cause any issues too Sold the Puma Defender and bought a brand new Pangea Green 2020 Defender D240 S with a few factory extras!
Post #849803 13th Aug 2020 6:06pm
LRSpain004
Spain
That is downright dangerous and scary. I hope someone at LR sees the video as we all know what could have happened.... Shocking.
Post #849804 13th Aug 2020 6:07pm
Smilesapart
J77 wrote:
I’m just not a fan of the gear selector at all, I found it was in the way of everything, perhaps just a case of getting used to it.
Oh really? I loved it. Sold the Puma Defender and bought a brand new Pangea Green 2020 Defender D240 S with a few factory extras!
Post #849805 13th Aug 2020 6:08pm
lohr500
Jerry wrote:
Thanks for posting this. That’s pretty concerning and I’m not surprised LR didn’t want it shown. Someone needs to work out what went wrong and fix it quick!
Well if Boeing could get the avionics algorithm wrong on the 737 Max, what hope for the cash strapped software developers within JLR?
I do worry about all these complicated systems and what could happen if they kick in unintentionally when travelling at speed down the highway.
Post #849811 13th Aug 2020 6:17pm
Smilesapart
Sorry but while it may or may not be true, I’ve seen so many convincing videos come out of that country that I later discover were made up propaganda to stir up Censored it ours and various other countries, or to get us to behave in a certain way, that I don’t believe anything I see coming out of that country any more. Sold the Puma Defender and bought a brand new Pangea Green 2020 Defender D240 S with a few factory extras!
Post #849822 13th Aug 2020 6:41pm
J77
You suggesting the Russians would sabotage a British brand Whistle
Post #849824 13th Aug 2020 6:43pm
ak34
Latvia 2008 Defender 110 Puma 2.4 HT Aintree Green
Acctually the reviewer liked defender. He noted some problems - mostly software glitches and that scary hill roll. And hopes that it will be fixed. One other thing he noted - he was not able to close sunroof when car flexes with wheel in the air.
Post #849833 13th Aug 2020 7:01pm
J77
If there was body flex causing issues with the sunroof, wouldn’t the glass crack? Which has happened some other models.
Post #849841 13th Aug 2020 7:57pm
Tim in Scotland
I’ve had the sunroof issue with it not closing and the cure is to fully open the electrically powered sun blind, then close the glass and the sun blind will close itself when the car is locked or you press the close button. There seems to be a sensor that makes it think that you have only tilted the opening section because the roller blind only leaves about a 10cm section open when you just tilt the glass, but if you then open the glass fully without opening the blind too it doesn’t like the glass to close again if you get my drift.
Regarding the car rolling backwards....... I wonder if he pressed the brake pedal with the HDC engaged? Doing that can release the HDC which does work in reversing situations as well as descending forwards. With the all season tyres on too the treads must have filled with mud making them slicks so he was in effect skiing backwards down the hill on four tyres. As we all know physics plays a big part in the game with 2.3tonnes of car sliding. I’m not trying to make excuses for LR because obviously something went very seriously wrong and needs to be investigated by LR and the findings/ cure published for other users to be aware this might be an issue if offroad in mud on all season tyres on a very steep incline. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #849842 13th Aug 2020 8:03pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
The wheels are all turning as it heads off backwards. Rgds.
Chris
Post #849848 13th Aug 2020 8:10pm
J77
Possibly cooked the DSC?
Which causes the Hill Start Assist to deactivate causing roll back.
Post #849853 13th Aug 2020 8:22pm
And poor performance, poor manoeuvrability, and inadequate brakes if I remember correctly. His test vehicle did seem to have a multitude of problems with the "infotainment" system.
Post #849854 13th Aug 2020 8:22pm
J77
He must have got a lemon.
The brakes on my demo car would stop on a 10p piece and give you 9p change.
Post #849855 13th Aug 2020 8:24pm
Tim in Scotland
I don’t understand where he finds the poor performance with the 240hp engine - on UK roads it’s more than adequate - maybe he’s worried that he won’t be able to get away from the KGB in their G63 G Wagens Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #849860 13th Aug 2020 8:25pm
ak34
He is in Ukrain. Threre are different car habits as in Russia. You should discount claims about poor performance, because good performance needs 5l supercharged V8 for them. G63 is how many there see perfect 4x4. In the same time, the guy boght Suzuki Jimny for himself. Fun car, but performance wise Defender is in different class.
Post #849893 14th Aug 2020 4:35am
This topic is locked: you cannot edit posts or make replies.  Back to top
