Home > Puma (Tdci) > Tuffy Box on Puma
surf110
Brazil 2009 Defender 130 Puma 2.4 HCPU Fuji White
Tuffy Box on Puma
Has anybody fitted a 12"wide Tuffy box on a Puma 110? Does it interfere with the hi/lo shifter?
http://www.tuffyproducts.com/p-89-017-delu...-wide.aspx
Post #83670 10th Aug 2011 2:02am
leeds
Have not fitted a Tuffy box to our Puma.
At 12" wide that does not give you a lot of clearance for the seatbelt. Approx distance between seat belts in our Puma is about 12.5 inches.
At 24" long including cup holder it is too long. It will interfere with high/low shift AND project into rear seat area.
Our cubby box is 10" wide and 19" long at the base. We had to get id of the cup holder. At 19" it just does not interfere with high/low shift and just does not project into rear seat area.
I think another choice of cubby box will be in order.
I know of one firm making a shorter cubby box in the UK for a Puma. I think they have done away with the front radio console as well.
Brendan
Post #83724 10th Aug 2011 11:18am
surf110
Tuffry makes a 10"wide without the radio console. Maybe that one will fit.
I have a 12"W on the Td5 and seems to work fine.
Post #83798 10th Aug 2011 7:46pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
try www.barebox.com Putting Dreams on Drives at JLR Solihull..
Post #84409 14th Aug 2011 9:12pm
KPNuts
England 2010 Defender 110 Puma 2.4 USW Alpine White
We have a Mobile Storage Systems one in our Puma. Mounted it slightly further back than designed and did not fit cup holder - only the tray. Radio mount retained. Occasionally catch the radio cover with hand when open, but not a problem.
Keith 2010 110 Utility Station Wagon
1996 110 Station Wagon
Post #84438 15th Aug 2011 7:54am
AndrewS
As above in the grey 130 but got a Loc Box for the blue one. The Loc Box is designed for the Puma. 130's have feeling's as well you know Smile
Post #84558 15th Aug 2011 6:37pm
surf110
Thanks guys. I think I'll try the LocBox.
Post #84964 18th Aug 2011 12:25am
