![]() | Home > Off Topic > Deutz Fahr experts? |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1330 ![]() ![]() ![]() |
Don't know anything about the Deutz dx3.90 and assuming it has a conventional manual gearbox, if the gears worked before he replaced the seal, then I am guessing it is going to be something simple like the end of the gear selector rod not being correctly located in the selector shafts inside the box.
My bid would be to remove the plate where he replaced the seal and look at the selector slide positions. Then make sure when the cover plate is offered back up to the gearbox, the end of the gear selector rod is located correctly in the sliders. Without knowing the set up, it may be better to select neutral by carefully moving the gear selector sliders as he may have got the selectors out of alignment by moving the shift lever when it was not properly located. |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2535 ![]() ![]() ![]() |
This may be worth a longshot if no one on hear can help:-
https://www.justanswer.co.uk/sip/deutz-fahr?r=ppc|ga|5|1621210534|70310861424|&JPKW=deutz-fahr%20problem&JPDC=S&JPST=&JPAD=318196700791&JPMT=b&JPNW=g&JPAF=txt&JPRC=1&JPCD=20181104&JPOP=&JCLT=&cmpid=1621210534&agid=70310861424&fiid=&tgtid=kwd-5983776652&ntw=g&dvc=c&gclid=EAIaIQobChMIpI27xsOL6wIVD-vtCh10OQ3VEAMYASAAEgLyNfD_BwE Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Thanks for the replies people. I will pass on the suggestions. 1999 Defender TD5 110
