Home > Technical > Nanocom |
I'm not sure that a Nanocom will help with that but your problem does sound very much like a sticky mechanism in, probably, the drivers door. The grease that they were originally lubricated with tends to go hard over time and the increased resistance produces the symptoms that you describe.
Take a look inside the door, clean off the old grease and re-lubricate the linkages to see if it cures the problem. Oh, and welcome on board. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
5th Aug 2020 8:22pm |
Gaz65 Member Since: 05 Aug 2020 Location: Herefordshire Posts: 2 |
LRA,
Thanks for your advice I will certainly give that a go and get back to you. Thanks for the welcome. |
5th Aug 2020 8:55pm |
