Home > Technical > play on parking brake
davidblythe
is this normal amount of movement between propshaft and parking brake/transfer box
out of gear with no hand brake on, rear wheels off the ground
&feature=youtu.be
Post #848045 4th Aug 2020 5:12pm
ibexman
It’s called backlash Whistle
Post #848055 4th Aug 2020 6:07pm
Retroanaconda
Are both the wheels on the ground?
Post #848061 4th Aug 2020 6:50pm
davidblythe
NO both wheels off the ground
Post #848063 4th Aug 2020 6:57pm
Retroanaconda
Then I’m not sure what you’re trying to demonstrate. With the box(es) out of gear everything is free to move so you can’t really see play compared to a fixed position. There’s clearly backlash in your setup though.
Put the main gearbox in gear and the transfer box in high and then see how much backlash you have. On a Tdci it’s likely to be the rubbish coupling shaft on the back of the gearbox.
Post #848075 4th Aug 2020 7:58pm
davidblythe
there is always a newby (me) still learning, asking dumb questions
have learnt a lot and wont ask the same dumb question again Laughing
Post #848415 6th Aug 2020 6:43pm
