Home > Technical > Lights help needed
spudfan
Ireland
Lights help needed
I fitted Ring Aurora DRL lights to two 2.4 Pumas and they work great and very easy to wire up. I decided to fit them to a 200 tdi and a 300 tdi but they do not work on the tdi Defenders. They light up on ignition then go out. Wired the very same as the Puma, two wires to the battery and one to the side light as per instructions.
The unit that does not work in the tdi (the 300 and the 200), I wired it up to the Puma and it works as intended.
I know modern cars (Puma) charge slightly higher than older cars (tdi) but I did not think that would make a difference to DRL lights. Anyway any ideas on whether I can get the DRL lights to work on the tdi? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #847420 1st Aug 2020 10:18am
grafty99
You may need to wire it through a relay on the Tdi's rather than using the Ring control box. Simple enough to do, just need a normally closed relay.
Wire the relay coil to ground and side lights. The switched terminals to ignition and DRL positive. When the ignition is active the DRLs will light.
When you turn on the side lights, it will power the relay coil and open the ignition feed circuit to the DRLs and extinguish them - as per law Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #847425 1st Aug 2020 10:50am
spudfan
Ireland
Thank you. That is how the work on the Puma. The 300 tdi is due to go in to get some work done so I might get them to do the wiring alteration you suggest. Many thanks Thumbs Up 1982 88" 2.25 diesel
Post #847427 1st Aug 2020 11:00am
grafty99
1990 Vogue SE
Post #847520 1st Aug 2020 9:02pm
