Home > Technical > Anyone know if D2 Anti Roll Bars are the same as Def 110? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17373 |
No, completely different due to the ACE (Active Cornering Enhancement) system fitted to the Disco2. Disco 1 might be though.
30th Jul 2020 12:50pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2166 |
I meant D1! Oops lol Instagram @defender_ventures
Empire Tuning - Agent |
30th Jul 2020 12:54pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
D1 front and rears fit Defenders fine but I am unsure if they have the same stiffness but must be similar as they are the same diameter AFAIK (based on the fact the bushes are the same diameter bore)
Steve 02' 110 TD5 Double Cab Rebuild Thread |
30th Jul 2020 1:01pm |
That work then! Mates got a set i can have for free. Just need new bushes and some spacers to suit my lift Instagram @defender_ventures
30th Jul 2020 1:04pm |
Remember that you will need the wider bushes and the corresponding metal retainers for the rear ARB as the Discovery uses the same type as the 90 which wont fit your 110
30th Jul 2020 1:33pm |
Noted!
Was going to replace with Super Pro anyway and the brackets are £10 so easy Instagram @defender_ventures Empire Tuning - Agent |
30th Jul 2020 3:31pm |
Just working more toward this.
I know ill need spacers to suit my lift which is roughly 2" on the front, little more on the rear as its a pick up. I was thinking 25mm spacers should be fine? Instagram @defender_ventures Empire Tuning - Agent |
8th Aug 2020 7:28am |
