![]() | Home > Off Topic > Default Will Thinner Oils Damage Your Engine? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
"What do oil weights mean? What does 5W-30 mean? Do thinner oils get better fuel economy? Do thin oils like 0W-20 protect your engine?
I spent some time discussing these questions with Mobil 1 engineers and am excited to share what I learned. There’s an incredible amount of testing and verification that goes into labeling a motor oil’s viscosity rating, which is the single most important factor for how a motor oil will perform in an engine. Motor oil is responsible for protecting your engine, removing contaminants, reducing friction and cooling your engine. Plus, motor oil creates a protective barrier between moving metal parts allowing for your engine’s longevity. In this video we’ll use a 6.2L V8 engine cutaway from the C8 Corvette to better see and understand how oil interacts with automotive engines." -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
