![]() | Home > Puma (Tdci) > Puma stalls after starting - despite searching no solution |
thr Member Since: 17 Sep 2008 Location: Northamptonshire Posts: 34 ![]() ![]() ![]() |
Is there some chance that it could be the VCV? Would that explain the stalling after starting and the intermittent nature?
Sorry if on the wrong track, running out of things that i can try. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4739 ![]() ![]() |
Check with the original owner that you have the original key. I had a second key supplied by Land Rover (I should have received two but only received one). They sent it to a maindealer who programmed it to my 110. This spare key will give me occasional non start issues. I would say it is a communication problem between your key fob and the Land Rover. 1982 88" 2.25 diesel
Thank you. I am the third owner, so it would be hard to confirm if the keys are original. I will keep a note of which set of the two keys i am using though to see if it is one key or the other that is an issue.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3478 ![]() ![]() ![]() |
Not sure if this helps, on 2.2 not 2.4, but I had a very similar issue. Mine was mostly firing and then dies right away.
I asked for help here: https://www.defender2.net/forum/topic73565.html I followed all recommendations, but I really have no idea what solved it..... seems like resetting the DTCs solved my issue however. I have not driven it much, just a test drive after it came back to life, and a couple of times just to take it out of the garage and back in. Hope you can sort it out soon. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks Dinnu. I read through this post previously. After disconnecting the wiring to the 10AS i had problems with the immobiliser locking on, but the technique in this peice for resetting with disconnecting the battery quickly solved that luckily. There is a lot of knowledge on this forum.
Hi Thr,
One thing that a friend suggested to me when I had the problem is to clean/replace the MAF sensor. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thank you. I will give that a clean as well.
Tom |
Yesterday i did 6 journeys, and it started first time every time. Tonight, wouldn't run. It would start, sort of half respond to some revs when i was trying to keep it alive, then die after a few seconds.
I cleaned the MAF sensor. Sadly it didm't work. I disconnected the battery to reset everything. It didn't work. In the end the battery died from all my attempts so that was that. Luckily i was at home not somewhere else. Car back on charge now and none the wiser as to what the cause is. |
Not good to hear. What I learned from my case is that you really need to read the diagnostic trouble codes. I used a cheap wifi ELM327, and OEBD facile app on my phone. You need to get paid version of the app to allow you clear DTCs, else only view. But it is really cheap.
With 2.4 I understand you can use Forscan on a laptop, will detect as a Transit, downloadable for free. But you still need interface cable. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Codes would be a great help. I am on the groupbuy for a nanocom very kindly organised by DieselDriver, so i should have it soon hopefully. If i am lucky it will tell me what is wrong, however i am quickly learning with this car that nothing is a simple as you think it is going to be.
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1953 ![]() ![]() ![]() |
When cold and the ignition goes on for the first time does the engine temp needle raise at all?
Also have you cleaned the MAP sensor as welll as the MAF? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Never heard of cleaning MAP sensors. On the other hand, MAFs are very sensitive to contamination. Another sensor that would cause the engine to die is the crank position sensor. Perhaps a connection issue there. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Quite a few threads on here about cleaning them, they do get sooted up quite bad with a few miles under their belt
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2118 ![]() ![]() ![]() |
silly question - but do you have both sets of keys in the wagon ?? this will cause some issues when staring ...
just a thought Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
