Home > Technical > What depth of foam to insulate roof? |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 |
2 layers of foiled-lined camping mat went inside my roof without any issues so circa 10mm. From memory there was more space available but the local Tescos had no more camping mats in stock at the time and I was in a hurry.
https://www.tesco.com/groceries/en-GB/prod...%26w%3D540 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
28th Jul 2020 2:00pm |
ChrisDefender Member Since: 29 Oct 2015 Location: Midlands Posts: 456 |
Pretty sure I used 12mm acoustic foam with a self ashesive backing with no problems. It's all stil up there anyway
28th Jul 2020 4:19pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3689 |
Nice one, thanks.
28th Jul 2020 5:48pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 |
I used 12mm closed cell foam and 3mm silent coat and it was tight! If I was doing it again with silentcoat/ dynamat or the like, then I would probably go for 10mm instead.
28th Jul 2020 6:57pm |
I used the black version of the silent coat too. To be safe it looks like the 10mm is a better bet so not to put any undue pressure on the headliner.
29th Jul 2020 8:15am |
