![]() | Home > Technical > Top Swivel Bearing Gasket |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
There shouldn't be a gasket on the top. The gasket if for the lower pin. The top pin should have a stack/single shim which is used to set the preload.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
HYLOMAR UNIVERSAL BLUE can be used to seal top swivel tin
Fatbaron Member Since: 12 Mar 2016 Location: Devon Posts: 299 ![]() ![]() |
Cheers Fella's. All sorted.
