Home > Td5 > rev counter stopped working
Procta
Looks like i have a touch of french electrics, The rev counter has decided to stop, i have checked the fuse and had a bit of a fiddle with where its tapped into in the ecu, and nothing. I have noticed a little bit of a flicker so it must be getting power.
Any ideas on what could have gone wrong? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #845077 21st Jul 2020 5:30pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Check your grounds for your gauges behind the binnacle. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #845087 21st Jul 2020 6:15pm
Procta
will dodgy earths make the gauge be hit and miss? It was reading ok and then started to act up, also if i put the blower on it starts to act up too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #845262 22nd Jul 2020 3:41pm
4RF RDS
Yes it could be a bad earth. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #845267 22nd Jul 2020 3:51pm
Procta
Spot on, i will have a look at some point next week, Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #845278 22nd Jul 2020 4:21pm
Dinnu
Is the tachometer on the W terminal of the alternator? Or I am still years behind in technology? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #845290 22nd Jul 2020 5:16pm
Procta
on these they are wired into the ECU, the older ones i believe are. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #845343 22nd Jul 2020 8:17pm
Nigelpugh7
If it helps our TD5 Rev counter stopped working, quite some time back, only got around to looking at it recently.
We assumed that the Rev counter had died,,we now know it was just the wire from the multiplug to the Rev counter that had fallen out.
Could be the same on yours?
But yes check the Earth too, just put your meter across the +ve and the ground with the ignition on to see if you have 12V.
These pics might help if it is the multiplug which was the problem on ours.
Post #846639 28th Jul 2020 12:46pm
Procta
I will double check that! to see if its just a daft loose connection Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #847927 4th Aug 2020 1:42am
roel
On my 90 there was no connection with the ecu for the rev counter, so I had to run a separate cable. So it doesn't have to be in that connector. Roel
2003 90 Td5 (2009-now)
Post #847945 4th Aug 2020 7:53am
Procta
well looks like i have a touch of french electrics, This works when it wants to, Give it some beans and the thing just stops working. Ie when you are going on a 70 mph road. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #853496 1st Sep 2020 6:05am
grafty99
I'd check power or ground to the rev counter. Does it drop to 0 rpm or below 0 rpm?
The reason I ask is that my rev counter sits below 0 until you switch on the ignition - it then rises to 0 until you start it.
If it's a dodgy earth or power feed then it will drop below 0. If its a dodgy ECU connection then it will only drop to 0 and not below Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #853662 1st Sep 2020 7:17pm
Procta
cheers i will have a look, but i think it could be a funny earth, When i have the lights on the selector for the window screen, and bottom heater ducts. the light goes out, and the comes back on again. Which i think is also connected with this rev counter problem. Not sure how the previous owner has the rev counter wired in. But i think i will have to look at the earths. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #856243 16th Sep 2020 6:10am
Procta
when i put the blower on, the rev counter starts to act up. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #862023 17th Oct 2020 12:57am
