Home > Td5 > Temperature guage problem?
Archer36
Portugal
I have a temp guage which is showing about 3 mm right of cold when on a run. In the past it has always shown about 4mm left of center on the guage.
I've only noticed this recently and due to this covid fiasco,as it hasn't used very much.
Could it be the thermometer sticking?, and if it is how much coolant will I need when I change it?
Are there any symptons to look for when in use , and will there be damage if I continue it as is?
Pleased to meet you all by the way, from hot Portugal
Post #844868 20th Jul 2020 2:12pm
excossack
Maybe;Faulty thermostat or faulty sensor?
Do you get warm air with the heating on? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #844870 20th Jul 2020 2:34pm
Archer36
Portugal
Heating works OK -
I was wondering if it was the thermostat which has stuck - are they prone to sticking? It is the original and I have had the vehicle since new in 2004.
Post #844879 20th Jul 2020 3:17pm
excossack
If you get get hot air then maybe worth swapping the sensor?
You could if you want also do the thermostat & coolant and as well.? 1999 Defender TD5 110
Regards
John M0VAZ
Post #844883 20th Jul 2020 3:30pm
Archer36
Portugal
So, is this the sensor on the cylinder head at the front, right hand side?
Is there any danger to the engine whilst it is in this condition ?
Post #844898 20th Jul 2020 5:06pm
roel
Your Gauge is ecu controlled. if I am right the temp gauge starts moving up at about 55-60 deg C and is more or less in the middle at 85 -90 C and stays there till above 100C and ten shoots to bloddy hot in one go. I don't know the temp on that moment.
If the gauge is moving a little it looks like it is doing something however you don't know if the sensor give a low reading or the gauge is not working properly. Dies somebody you know has a Nanocom or something like that to read the temp from the ecu? Roel
2003 90 Td5 (2009-now)
Post #844899 20th Jul 2020 5:33pm
Archer36
Portugal
Thanks -
When it has been working normally in the past, on a hot day, there is another noise which occurs which I assume is the inter-cooler (it sounds like a fan cutting in), and if I am right, what does this do, because if it is the sensor that is at fault and it is working off the ecu will this affect the inter-cooler cutting in? Sorry, I don't know much about the inter-cooler and how it functions. This is why I asked the question - whether it could do damage to the engine as the inter-cooler is not now cutting in ...
Post #844904 20th Jul 2020 5:50pm
PCM
Not sure what defender you have, but on mine (Puma) The thermostat reaches a certain temperature then activates the viscous fan in the big void behind the radiator. This happens with standard thermostats at 88 degrees. This fan them blows on the radiator and helps cool the engine.
If there is an issue with your thermostat and it's either getting stuck or just broken the thermostat won't activate the fan and the car could overheat.
In hotter climates (Probably yours) you can change the thermostat to one that activates at 82 degrees therefor helps coo the engine sooner.
From what I know a cooler (but still warm) engine is probably better on all counts it's just not as good for emissions.
The thermostat is in the pipework on the left side of the radiator next to the left side head light. It's a simple swap out and replace jobby if you clamp the hose.
The needle on the temperature gauge on the defenders is pants. It's ok then just red.
More info on the thermostats etc. in a link below:
https://www.defender2.net/forum/topic32086...thermostat
It's a 30 min job. I'd definitely buy the 82 degree one and have it fitted. While you're there just change the fluid too as it can't hurt.
Also check the radiator is not clogged full of dust and crap. This could also be an issue.
Post #844965 20th Jul 2020 10:24pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
The sound you are likely hearing is the clutch fan engaging to help cool the radiator and the engine coolant. The intercooler has no moving parts and does not make a sound. Thumbs Up
Archer36 wrote:
Thanks -
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #844970 21st Jul 2020 12:32am
Remember that the viscous fan is totally self-contained and not connected in any way to any sensors.
What year is the vehicle in question? It would be easier to make suggestions if we knew what engine it has.
Post #844980 21st Jul 2020 6:49am
roel
It is in the td5 section so I assumed a td5 Very Happy
But as I understand assume means making an ass out off you and me. I could be wrong. Whistle Roel
Post #844984 21st Jul 2020 7:14am
roel wrote:
...It is in the td5 section so I assumed a td5 ...
A fair point, well made, and one which I had completely missed! Embarassed
Post #845005 21st Jul 2020 8:19am
