![]() | Home > Puma (Tdci) > NAS Lights Fitment Issue |
trailbear Member Since: 14 Sep 2016 Location: Scotland Posts: 405 ![]() ![]() |
Sorry, not sure how they have ended up oriented like that, technology confuses sometimes!
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 207 ![]() ![]() ![]() |
On the NAS Defenders, the lights were all fitted at the bottom. How you have it is non-standard. Maybe a gas door strut would help?
![]() Find a Defender's history and spec: https://defender.lrworkshop.com |
A comparable setup was used on the SVX specials, though.
To be honest, I've had NAS lights fitted on three different Defenders and the wheel always gets close. It's not an issue, though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
This I believe is how the SVX lights were fitted so perhaps I should have said that then.
However, I surely can’t be the only person to have encountered this issue. I have seen many on the forum fitting theses lights in this position. |
For some reason, mines will definitely shatter my new and expensive set up😳
Are you running larger than standard tyres, by any chance? Darren
265/ 65 R 18
I am thinking if that is the problem then perhaps a gas strut set up?
As will@LRW suggested
Defender upgrades sell shallow plinths that may help. Ray
I’ll have a look at that, I have the gas strut from another vehicle so may start there.
Hmm, on paper at least they're ever so slightly smaller than standard 235/85 16's. If your 18 inch wheels have a greater offset than standard then that might explain it. It sounds a bit odd, to be honest. It'd be worth taking a look at the door stay to make sure that the stop is properly in place. Failing that, you could try adjusting the mounting of the body end of the stay forwards slightly, which could be enough to solve the problem. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks
I will have a look tomorrow and see where we go from there. I do think that it is slightly odd though. |
siglo Member Since: 07 Aug 2015 Location: Kuwait Posts: 50 ![]() ![]() ![]() |
I remember that I've run into this issues when i first installed the NAS lights with the stock spare, but I honestly don't remember how we fixed it. There must have been a screw that allowed adjustments or we added spacers or something. I remember after fixing this problem the door would not open up all the way like before. These photos are before fixing the issue, I couldn't find ones after fixing it with the stock spare carrier.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Later on when I got a larger spare, I've already changed to a frame mounted tire carrier that can be adjusted so I adjusted the carrier. I found this photo while we were working on the door, maybe it would help. ![]() Click image to enlarge |
