Home > Tdi > 300tdi Rear Caliper circuit question?
KiwiNCFC
United Kingdom 1997 Defender 90 300 Tdi HT Arles Blue
Hi guys,
Recently fitted new calipers/Flexi hoses/wheel bearings/discs/pads/fluid flush to the front and all is good, thanks for the tips in a previous thread on here!
I've now moved to the back where I am replacing calipers and discs/pads and I have ordered some Calipers which are (SMC500240 or STC 1265R etc).
Just looking at the caliper below there seems to be 2 brake pipe connections. My current caliper has the pipe going into where the orange bung is. This is obviously where I plan to connect into but I've noticed there is another connection above it which has the little 10mm bolt in. Can this bolt stay in? Or does the caliper require 2 separate lines to feed the piston on the other side of the caliper? Tried to search but to no avail!
Hope someone can enlighten me ! 🙂
Post #844712 19th Jul 2020 11:47am
donmacn
Happened to have my old ones handy. Doesn't look like that extra bolt does anything.
 Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #844721 19th Jul 2020 1:04pm
KiwiNCFC
Ah great thanks! That puts my mind at rest. Just wonder what it's for 🤔
Post #844756 19th Jul 2020 6:44pm
The bolt will be plugging a hole required to drill one of the internal fluid galleries.
Post #844765 19th Jul 2020 7:04pm
