Home > Puma (Tdci) > noisekiller engine blanket highly recommeded
rossy
I fitted the above today. It takes 5 minutes and I am astonished by the result - the engine noise has halved.
They do a special L shaped one for the Puma. Its £95 well spent - no need for the rest of the kit which is £280. You use the 3 releasable cable ties but I would get a couple extra so you can find suitable solid anchoring points. You can still access the dipstick with it fitted too.
I also covered the rear wheel arches with butyl flashing (two rolls of 5m x 150mm from any builders merchants) and that has halved the splashing sound you hear when driving on wet roads (raining all day here) so it must work. The rest of the car is pretty well sound proofed at the factory I think so job done ! Very Happy
Post #84151 12th Aug 2011 10:20pm
K9F
You're not the first to sing the praises of this this product: - Thumbs Up
http://www.defender2.net/forum/topic4496.h...oisekiller
http://www.defender2.net/forum/topic1183.h...oisekiller If you go through life with your head in the sand....all people will see is an ar5e!!
Post #84152 12th Aug 2011 11:12pm
dgardel
Italy
Re: noisekiller engine blanket highly recommeded
Very Happy
Could you post pics? Bow down Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #84273 13th Aug 2011 8:57pm
rossy
just back from work. Will do in the morning Thumbs Up
Post #84277 13th Aug 2011 10:04pm
rossy
there you go
what isn't visible in the photo is the flap that tucks down the back of the engine hence the L shape overall. You just have to bend it away from the exhaust manifold.
You can also get an under bonnet kit but I think the blanket is better as it muffles the din at source
Post #84314 14th Aug 2011 8:38am
Happyoldgit
I had a Td5 one which I shifted from vehicle to vehicle, it worked well. Steve.
http://forums.lr4x4.com
Post #84332 14th Aug 2011 11:36am
spudfan
Ireland
What is behind the plastic circle with Land Rover on it on the lefthand side of the engine? My 2008 Puma does not have this. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #84339 14th Aug 2011 12:39pm
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Its the cover plate for the air con compressor drive belt and pulley Thumbs Up
Post #84348 14th Aug 2011 1:50pm
spudfan
Ireland
That explains it-I do not have airconditioning. Thanks Thumbs Up 1982 88" 2.25 diesel
Post #84349 14th Aug 2011 2:33pm
dgardel
Italy
rossy wrote:
there you go
Thank you mate Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #84366 14th Aug 2011 5:17pm
dgardel
Italy
rossy wrote:
there you go
IID Pro MV License
Post #84367 14th Aug 2011 5:17pm
Naks
just wondering that this will do to the engine temp, esp in warm climates... --
Post #84370 14th Aug 2011 5:37pm
pom
hmm expanding foam all the gaps should do the trick.....
Pom
Post #84378 14th Aug 2011 6:48pm
nikojo
Do you have pictures of how you did the wheel wells??
Did you just stick on top from the inside??
Post #94648 17th Oct 2011 3:42am
rossy
sorry nikojo just noticed this but no pictures I'm afraid. I just plastered it on from the inside and put the carpet back on - job done and hidden !
Post #94931 18th Oct 2011 7:04pm
