- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
rallysteve
You have reconnected the Dim-Dip resistor which brings dim headlights on with sidelights. Disconnect the resistor which is on the inner wing just near where you made the repair. That should solve your DRL issue.
Steve 02' 110 TD5 Double Cab Rebuild Thread
9th Jul 2020 6:25pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
