Home > My Defender > Bodstruck 200tdi 90
Page 3 of 4 <1234>
Mariner
Ireland
I also had that clunk sound when setting off and it was the A frame Bush over the rear axle that needed to be replaced.
It might be a good place to start your detective work. Wink
Post #842002 5th Jul 2020 11:43pm
bodstruck
Good pointer, thanks. Had a little look this morning and there is certainly some play in the a frame balljoint so can probably expect the same in bushes.
Not sure I can face this job myself though so a trip to ASV in tidworth may be in order.
Post #842056 6th Jul 2020 9:19am
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
What is "ASV in tidworth"?
Post #842190 6th Jul 2020 8:22pm
bodstruck
4x4 garage. Not used them myself but close to me and highly recommended by the locals.
Post #842193 6th Jul 2020 8:37pm
Danny Fireblade
Thumbs Up
Post #842201 6th Jul 2020 9:08pm
bodstruck
Fitted the cyrix battery combiner over the weekend. Already had some 16mm cable and crimps so a fairly straightforward job. No pics of this at the moment but all goes together very well. Now have two 95Ah batteries linked with most of the 12v accessories coming off the second battery.
Rear step is painted and back on.
Changed the wing top vents. Not sure what they were exactly but didn't like the raised ones that came with the car so went back to standard, with a fresh coat of satin black.
Final job this round was fitting the new tyres. I bought a set of 4 Goodyear wrangler mt/r in 235/85/16 to replace the special tracks. Had them fitted to a set of modular rims I bought a few weeks ago.
Looking good i think.
The offset is different to the freestyle alloys. They looked a bit Carlos fandango when I first fitted one so I took off the 30mm spacers and they are just right (IMO anyway). ET08 modulars.
Out:
In
Raining so fitted in the garage, not great pics of them fitted.
Running out of stuff to do now. A bit longer before the roof rack legs arrive. Will get the a frame balljoint and, if needed, the bushes done in the next week or so. Should be job done then.
Post #842623 8th Jul 2020 5:57pm
L110CDL
Looking good there Thumbs Up
Did you say " job done " then when the bushes are done, surely not Wink Clayton.
Keeper.
Post #842875 9th Jul 2020 8:09pm
bodstruck
Thank you.
I suppose it will be job-ish done. I'll have done the spruce up I had planned but there will be lots more to come once it gets used
I decided not to wait for the new roof rack feet i cut the originals which were joined at the bottom and then put on pair front and one back. Still very solid and will do the job for now.
Fitting was an interesting challenge on my own but with some ingenuity, wood and hop-ups I got it on and secured.
I have now sold the leather seat and will use the money from that to retrim the vinyl ones.
Then took the opportunity to take it for a spin on the plain and took a few pics while up there.
I have ordered one more wrangler mt/r which gets fitted to the spare rim on Tuesday and on the same day it is off to have the a frame ball joint replaced and bushes checked (and replaced if needed).
Post #843181 11th Jul 2020 7:08pm
L110CDL
What a great transformation you have done there, a real credit to you Bow down Clayton.
Keeper.
Post #843761 14th Jul 2020 7:56pm
bodstruck
Thank you very much. I am pleased with it and love the way it looks.
Not much done recently, put fuel in and driven it around. Running well and now I have had the a frame ball joint replaced the annoying knock has gone.
I debated using the light bars that were originally on the truck but could not really work out a decent fit so I decided to buy a new one. Clearly lots of options but rather than spend a fortune on something that I am not too sure how much it will get used I opted for finest chinesium. There was already a flat ally bar fixed to the rack where twisted originally mounted a light bar so i just drilled that and bolted the new one in.
New tyre fitted to a matching modular rim and popped on as spare, now have 5 matching and thena second spare with a BFG MT on it.
Next job is to fit the new seat trim kit on the drivers side. I have also ordered a heated seat kit so need to wait for those to arrive before I fit.
Post #845352 22nd Jul 2020 7:46pm
L110CDL
Nice additions there Thumbs Up Clayton.
Keeper.
Post #845353 22nd Jul 2020 7:49pm
bodstruck
Well, slight snag. Seat cover was for a puma seat and didn't fit. Replacement sorted and fitted today.
Old was was definitely a bit shot
Added a heated seat kit while I was at it
End result
Next job- wire up the seats. I think I will put the switches and relays in the cubby box.
Post #847147 30th Jul 2020 9:37pm
L110CDL
Cracking job there done with the seat Thumbs Up Clayton.
Keeper.
Post #847343 31st Jul 2020 8:05pm
bodstruck
Thank you, very happy with the way turned out.
This weekend jobs - first, meet up with couple of other defenders for a day out on Salisbury plain.
It behaved itself very well.
Back to finishing up a few jobs today.
Wired up the light bar. It might be a cheap Chinese version but it is flippin bright.
Fitted a replacement CB. Managed to get one with the same dimensions as the duff thunderpole one so it fits into the raptor dash.
Then took the centre seat out so I could refit the cubby box. The plan was to install the wiring for the heated seats in it. I had fed an extra switched live cable from the dash when installing the other wiring so had a feed for it. Put the switches just in front of the cup holders. All the other Gubbins is inside the cubby and I will hide that under a false floor.
It all look quite neat and the heated seat pads work very well.
Next jobs - CB aerial, get a decent Jack, service kit for the engine and drive and enjoy it some more. And a quick trip to Coventry in the week to collect a hannibal roof tent and another roof rack.
Post #847691 2nd Aug 2020 8:27pm
L110CDL
Looks as if you had a good time on the plain Very Happy Clayton.
Keeper.
Post #848088 4th Aug 2020 8:20pm
Page 3 of 4 <1234>
