Home > Technical > Td5 rear wiper electrics |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
I would check the wiring where it runs between the rear door and body (in the convoluted sleeve) as this may well have fatigued and broken.
Does your heated rear window worK? This is normally the first thing to fail in that wiring bundle. Steve 02' 110 TD5 Double Cab Rebuild Thread |
1st Jul 2020 12:15pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6610 |
What year of Td5? The rear wiper electrics changed when the 2002 dash came in. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
1st Jul 2020 12:23pm |
What year is your TD5? If it's post '02 and has the later rear door then the relay is inside the door itself:
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
1st Jul 2020 12:25pm |
cee-b Member Since: 25 Jan 2018 Location: South West Posts: 117 |
It is a 05, so the relay is as shown in the pic - thanks Anorak.
The heated rear window is working OK and I waggled the wires in the sleeve to see if it made a difference. I'll get back once I've checked the relay. Thanks for the answers so far. |
1st Jul 2020 12:43pm |
Sadly the relay works as advertised, so that is another easy fix eliminated.
All down to any advice on voltages to look for then please guys. |
1st Jul 2020 1:18pm |
Fit the relay again and turn the ignition on.
Get a length of wire, and stick one end in the relay holder cavity with the black/green wire, and tap the other end on a ground point (e.g. a nut on the door). This should trigger the relay and make the wiper run. If it works, then the trigger from the rear wiper switch is broken somewhere. If not, then the ignition supply to the door is the next place to look. Martin 1988 90 Td5 NAS soft top 2015 D90 XS SW |
1st Jul 2020 1:59pm |
I did as advised thanks Martin.
Tapping the Black/Green to earth did not operate the relay. I then took what, to me, seemed like the next logical step. I also took a 'flying lead' from the White/Green (solenoid supply) and put a voltmeter across the 2 leads with the intention of checking the voltage. This DID cause the relay to operate, but not the motor to run. After a couple of clicks of the solenoid, the 10A fuse blew. Perhaps it wasn't such a logical step as I'd thought! |
1st Jul 2020 3:48pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2244 |
Most likely the wiper shaft in the motor has seized.
1st Jul 2020 4:25pm |
Thanks Mo, but no.
As I said in the original post, when I put 12v across the motor it was fine. It is well greased and really smooth running. |
1st Jul 2020 4:42pm |
My bad, I failed to spot that in the original post.
1st Jul 2020 5:53pm |
I've done a bit more dicking about with flying leads and a multi meter.
The relay was working and putting 12v to the motor on the Red/Lt Green wire. The motor is good - I had already tested it. That only really left the Earth wire for the motor. Yup, that was open cct. I'll have a look tomorrow and see if I can find the break - if not, I'll just splice in a new earth. Thanks for the help and suggestions. Electrics are not my favourite system; anything that leaks without leaving a puddle is the Devil's work Cheers |
1st Jul 2020 7:05pm |
TMAX400 Member Since: 28 Nov 2015 Location: Edinburgh Posts: 1 |
Sorry to jump on this thread with more questions, but my problem is similar. 2004 90 TD5. In rear quarter panel my white/green wire has become detached at the 6 way plug. Re-connecting it does not allow the wiper to function. However, if I apply 12v at that point to the white/green wire, wiper works.
I believe dashboard switch is a negative switch (one black/green, one black, one orange illumination wire) So problem seems to be between dashboard switch (or front of the car) and rear quarter panel. Any ideas? Is there a relay between switch and rear quarter panel? Cheers |
12th Sep 2020 5:45pm |
