Home > Off Topic > Here’s a challenge. Unusual socket needed. |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Try octagon socket or 8soded socket
25th Jun 2020 4:14am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
Try a company called Melform Limited. They are based in Sheffield. They used to manufacture octagon hub nut spanners for early MG's, they may well have a range of sizes.
https://melform.net/ Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
25th Jun 2020 5:55am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
This place does unbelievable sized sockets in some exotic materials but they also do 8sided ones in various sizes/depths but sadly they are in America and i dread to think what the prices are:
https://www.imperial-newton.com/impact+soc.../standard/ Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
25th Jun 2020 6:51am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
Remember that an octagonal socket is different to an eight-point socket (the latter is not too hard to find, often called a double-square). Is it genuinely an octagon you require? The illustration below (from the excellent Imperial Newton website) illustrates the difference.
Any chance of a photo of the fastener you need to deal with, just in case other "outside the box" solutions can be found? Click image to enlarge Last edited by blackwolf on 25th Jun 2020 9:10am. Edited 1 time in total |
25th Jun 2020 7:57am |
By my reckoning 1.9/16" AF is a sliver under 40mm.
Deltec and ISS both list octagonal sockets, ISS lists a 1" drive 41mm Budd Octagonal socket at a very modest £23.40. I would have thought that 1.3mm oversize on 40mm would work. Most octagonal sockets tend to be quite a lot larger since they are intended for hub (wheel bearing) nuts. Deltec is a bit secretive on sizes but might be worth a call. Be aware though that unless you can find a relatively common Budd wheelnut socket (like the link above) that will do the job, you are probably looking at well over £100 for a specialised octagonal socket, which may be unappetising! Have you considered making a traditional box spanner from a length of thick-wall tube? |
25th Jun 2020 9:04am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
Thought I had one, but no. It’s 1”13/16 8point deep.
Sorry. |
25th Jun 2020 4:24pm |
DuncanS Member Since: 06 Dec 2013 Location: Cumbria Posts: 299 |
Yep Deltec do them. If they won't let you buy direct, let me know as we carry a large stock of their products and order off them every couple of days usually. I'll have a look on our shelves tomorrow in the "archives" as thats exactly the daft sort of thing we'd have in there.
As an aside Deltec also do specialist socket "hire" so that may work for you if its a one off. North Cumbria Search and Rescue - Team Leader |
25th Jun 2020 5:23pm |
tyrannosauROSS Member Since: 24 Jun 2016 Location: Kent Posts: 136 |
Thanks for the help.
I do indeed need an octagon shaped socket. I’ve attached a few photos for you guys to see. I’d be interested in the hire option if it’s cheep enough. Seems silly to spend money on removing one nut. At this stage I don’t intend to reuse it again as I want to make it so that any modern human can take it apart should they need to in the future. Ross Click image to enlarge Click image to enlarge |
27th Jun 2020 5:17pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1316 |
Hard to make out exactly how it is configured from the photo. But if it is just a simple eight sided nut and you don't intend to use it again, how about drilling down one side of the nut to put a split in it then it should turn relatively easily with plenty of oil, maybe a bit of heat and a pair of grips. Or even drill down both sides so it splits in two.
27th Jun 2020 5:24pm |
