Home > Maintenance & Modifications > POR 15 on rear cross member
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Hi after some advice I am about to give the rear crossmember so tlc and rub back and repaint I want a good rust preventer and hard wearing gloss finish. Is POR 15 the best option can in be hand painted and leave a smooth finish or better sprayed.
Thanks in advance
Andy Andy
Defender 90
Defender 110 XS
Cupra 290
Post #839845 26th Jun 2020 11:50am
markb110
Hi
I am guessing all experiences will be different but here is mine
I have used POR 15 in the past, it’s a good paint but it is nasty stuff and you don’t want it on you. The paint in the tin does not keep and will go rock hard if you don’t use it all, then it is wasted.
Obviously preparation is key for a good finish.
I have since moved over to Corroless glass reinforced chassis paint. The shelf life once open is very good, I’ve also used it on tools to refresh them
It brushes on really well and does no leave brush marks so you won’t need a spray gun. It is also ready in 30 minutes for a top coat.
Buzzweld, actually use paint source from Corroless and actually do a kit with everything you need to paint the rear crossmember.
It won’t be gloss black, more of a matte finish, and textured
You could go with the Corroless base coat then overspray it with a gloss paint.
Good luck Thumbs Up
Post #839852 26th Jun 2020 12:30pm
POR15 is an excellent chassis paint but unless they've changed the formula, it's not UV stable and therefore not recommended for areas that could see direct sunlight. Darren
Post #839863 26th Jun 2020 12:54pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I did mine using POR15 kit last time, after reading recommendations here.
I had 2 tins (sorry can't remember what each was called), but the undercoat went on really nice, smooth, no brush marks. Then the top coat (which was probably the chassis black, meant to protect the undercoat from UV) was horrible to brush on, left brush marks but I did my best. Looked reasonably good afterwards but started to peel off the undercoat after around 18 months. After a couple of winters it was looking tatty again, and yes I did the best prep I could.
I'll probably give Buzzweld a go next time.
Post #839877 26th Jun 2020 2:31pm
mk1collector
With por 15 you need to use the full system, so they have a degreaser to use first then a metal prep then the paint then top coat. As above the paint goes on nice but the brush on top coat isn’t brilliant so I use the paint followed by the spray on clear top coat that is uv stable Thumbs Up read up on the full recommended times for drying decorating etc to see if you want to get into the big job!
One I did last week with por15
A before shot just for reference
Edit: and after the metal prep stage, before painting.
 Ray
My build thread
Post #839887 26th Jun 2020 3:38pm
