Home > Td5 > Not charging :-(
excossack
Not charging :-(
All was well. Started off fine, went to the jet wash. Started the car, battery light stays on.
Drive for 5 mins, intermittent battery light but still no charge.
Check fuses all look good.
Check output from alternator, 11.7v Sad
Got the battery on the CTEK at the mo.
Before I buy another alternator...any more things to check? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #838448 20th Jun 2020 9:17am
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
Sounds like alternator I’m afraid. If it’s only 11.7v switched on sounds like rectifier circuit has blown a diode or two check with engine running and ancillary son should be an output of about 14v sorry 😐
Post #838465 20th Jun 2020 10:21am
Did you jetwash the engine compartment?
Otherwise classic symptoms of a failed alternator, usually in my experience on a TD5 because the vacuum pump has filled the alternator with oily gunk. If so, my advice is bite the bullet and fit a.new OE quality alternator and pump
Post #838472 20th Jun 2020 10:40am
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Worth checking that the multipoint loom that plugs in the back of it is still plugged in and not full of crap
Did you jet wash the alt at point blank range? Insta: @thebenjordan4x4
Post #838473 20th Jun 2020 10:41am
excossack
No jet washing of engine bay took place. Just a unahppy coincidence I think. Sad
I did check the multiplug and still attached. 11.7v at the back of the alty with engine running.
Also checked the brake lights worked - and they do. 1999 Defender TD5 110
Regards
John M0VAZ
Post #838507 20th Jun 2020 12:20pm
excossack
No jetwashing the engine bay.,
There is oil on the alty and on some pipes below. Another Denso to order, last one was about 2-3 years ago 1999 Defender TD5 110
Regards
John M0VAZ
Post #838508 20th Jun 2020 12:22pm
roel
I would take the alternator apart and have a look. Could be as simple as a stuck Carbon brush (Is that correct englisch?)
It could be that the 11.7 Volt is the battery with the fuel pump running etc. I think the alternator is doing nothing. Roel
2003 90 Td5 (2009-now)
Post #838589 20th Jun 2020 8:13pm
landy andy
Yes correct English Roel. Well done Thumbs Up Thumbs Up
Post #838594 20th Jun 2020 8:17pm
Sadly it seems to be really difficult to find spare parts (like slip rings and brushes) for the TD5 alternator.
Post #838623 20th Jun 2020 9:56pm
excossack
it does appear difficult to find parts Sad
The alternator is out. Two awkward bits, removing the multipin plug from the rear and the bottom oil drain pipe.
On the plus side, I found the original reciept for the alternator dated late 2018, so just under warranty(i hope).
I have sent an email to the company I got the alternator from, so lets see what they have to say. 1999 Defender TD5 110
Regards
John M0VAZ
Post #838719 21st Jun 2020 12:37pm
dorsetsmith
Post #838742 21st Jun 2020 3:06pm
excossack
Cheers DS. I still have the original one that was replaced by this one that has failed!l, so might run that one down to the autosparks place to see if they can ID the failed parts. 1999 Defender TD5 110
Regards
John M0VAZ
Post #838754 21st Jun 2020 4:14pm
excossack
Faulty one going back to the supplier for testing. 1999 Defender TD5 110
Regards
John M0VAZ
Post #838909 22nd Jun 2020 2:53pm
excossack
Alternator picked up and off to be tested. 1999 Defender TD5 110
Regards
John M0VAZ
Post #839393 24th Jun 2020 2:36pm
excossack
Alternator sent back, confirmed as faulty and refund given. 1999 Defender TD5 110
Regards
John M0VAZ
Post #843009 10th Jul 2020 2:19pm
