![]() | Home > Maintenance & Modifications > Brake Pad Change Defender XS fitted with brake pad sensors |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
What are 'sensors'? Never forget: cars have owner, Landrover have field service personnel.
Nostromo Member Since: 17 Jul 2015 Location: The Mendip Hills Posts: 73 ![]() ![]() |
Pad wear indicator sensors ? 🤔
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 ![]() ![]() ![]() |
You sure it's not the brake fluid level warning light? Rgds.
Chris |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4232 ![]() ![]() ![]() |
There are no brake wear sensors. Must be low brake fluid warning light. 2007 110 TDCi Station Wagon XS
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
As noted above, no Defender* has pad wear sensors. As the pads wear, more fluid is needed from the reservoir in order to make an application and consequently the fluid level in the reservoir lowers, which may result in the low fluid warning lamp flashing occasionally (it is most likely to do so if brake when going down hill, due to the design of the reservoir and location of the float switch).
If this is happening you are wise to check the pads (all round) for wear, but you may find that you just need to top up the reservoir a little. I find the the level needs to be maintained virtually at the bottom of the filler neck to guarantee that the light doesn't flicker on hard downhill braking. * I should probably say "no pre-2020 Defender" since the new thing may have them. |
Thanks everyone for the above info.
Just checked it out and indeed the brake fluid is a bit low . . . front pads definitely need changing out for new whilst the rear pads have approximately about 4mm still to go to be as low as the fronts. Thanks for the info about the warning light . . . I was convinced I was looking at a pad wear sensor warning on the dash !!!... so we live and learn !! ![]() It'll also explain why i couldn't find any pads with wear sensors on line !!! ![]() Just got to decide what sort of pads to buy now . . . last lot I bought for my other vehicle (T4 VW van) were Pagid and they've been very good on the van so I might go with those ? Cheers and thanks again. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8168 ![]() ![]() ![]() |
Delphi work well and last ok. Cheers
Thanks,
Will look Delphi up as well ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3655 ![]() ![]() ![]() |
best to buy a fitting kit as well just in case they are corroded DEFENDER 90 TDCI XS,
Just as an aside . . . .
Does anyone know the correct spec brake fluid for a 2015 Puma 2.2 90XS ? I've found part number LR052652 mentioned in my service paperwork but have no idea what brake fluid spec this represents ? Thanks ![]() |
Pjembe Member Since: 21 Jul 2015 Location: Newbiggin by the Sea Posts: 143 ![]() ![]() ![]() |
DOT 4. Available from most car parts shops (Halfords etc)
