![]() | Home > Maintenance & Modifications > Oils and quantities for service change 2015 2.2l Puma |
RichLech Member Since: 09 Nov 2015 Location: West Sussex Posts: 115 ![]() ![]() ![]() |
This is what I put together for my 2012 2.2 Puma. There is also a "sticky" at the top of the Puma section of this forum.
After studying information online and consulting Opie Oils for advice, Concluded that the following oils are appropriate: Engine 7 litres For the engine equipped with DPF, oil needs to be 5W-30 to spec. Ford M2C934-B (low SAPS). Opie oils has several. Selected Millers XF Longlife C1 5W-30 Synthetic. Gearbox 2.2 litres Handbook says Castrol BOT130M but this is not generally available. It is a synthetic 75W/90 GL-4 spec. Selected Castrol Syntrans Multivehicle 75W-90 GL-4 synthetic . Transfer Box 2.4 litres Handbook recommends Castrol Syntrax 75W-90 or equivalent. Selected Castrol Syntrax Universal Plus 75W-90 GL-5 synthetic Diffs 1.7 litres each Handbook recommends Texaco Geartex EP 85W/90 or equivalent. Opie Oils recommended Castrol Syntrax Universal Plus 75W-90 GL-5 synthetic |
Nostromo Member Since: 17 Jul 2015 Location: The Mendip Hills Posts: 73 ![]() ![]() |
Very many thanks . . . exactly what I needed to know.
It's worth noting that both the diffs and transfer box are 'fill to spill', i.e. fill until it starts to come out of the filler plug. The gearbox however, is fill with a measured amount and overfilling is a bad thing. Darren
Thanks for that Darren
