Home > Tdi > EGT temperature gauge
frenchy
I'm in the process of some 'mild tweaks' to the 300tdi including boost pin & ring, silicone hoses and a replacement intercooler.
As had been said, with these things being able to monitor the EGT, is very important.
The digital readout EGT gauges I think would look out of place in an older defender so have spotted this which seems to tick the right boxes....
https://fourby.co.uk/epages/950004277.sf/s...s/EGTROUND
However, the product description advises.....
" Due to the length of the probe, this is not suitable for a 300Tdi installation if you plan on using our boss at the manifold where the EGR used to be.
However, if you want to mount it somewhere else in the exhaust stream, it would work.
has anybody solved this issue, and if so, how??
The thought of drilling / tapping / welding the exhaust manifold fills me with horror (even if I could.....which I can't Embarassed )
My thoughts were adding additional EGR blaking plates to 'shim' the probe into a higher position.....or is that too 'bodgey'????? 2000 D2 TD5 - ahhh bless
2006 D3 - no longer with us and sadly missed
1997 300tdi d90 - now with electrics that work!
- now with a brand new custom made soft top fitted
…...…...............….new chassis now all fixed and driving like new
2010 D4 alas no more, but a lovely colour (Nara)
2016 D4 battery magically fixed with NOCO charger
Post #837479 16th Jun 2020 9:25am
donmacn
It's hard to tell in a way, because they don't have a picture of the probe itself on the link.
I've just recently installed an EGT probe, as part of a 'Madman' EMS kit. I've got this pic of their website:
It is quite long - and definitely far too long to fit straight down.
However, on their instructions it does say that the probe will need to be bent to fit into the exhaust stream, and not foul the sides of the manfold. I was quite lucky in that I had an alternative turbo to hand. I was able to fit the probe to the EGR plate and bend it, then offer it up to the new turbo and see how it fitted, I found I had to bend it a little more than I expected. This is a little nerve-wracking, but it's working fine. Quite scary in fact to see how the temps vary so much, so quickly and so easily! A definite case of 'new data anxiety' Shocked
Maybe the probe fourby are supplying can't be bent, or they don't want to advise that for DIY installers?
On the other hand, maybe it's the same probe, and could be quite easily bent up into the manifold?
So, sorry that I don't have a definite answer for you, but maybe some food for thought. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #837491 16th Jun 2020 10:19am
Mo Murphy
We used to do the same as Don with the 300 tdi, bending the probe gently until it fitted. Drilling a slightly larger hole in a block of wood and bending in the hole is probably the safest method of bending.
On a 200, location is a little easier but you have to drill your own hole !
The Fourby digital gauge works quite well on a TD5 dash in a Carling switch holder.
HTH
50 Shades of Pennine Grey
Post #837498 16th Jun 2020 11:10am
frenchy
Thanks for the replies.
I questioned the same thing to Fourby and Steph has (just) responded saying the probes are actually TOO SHORT to fit Shocked
I never considered they would be too short.
Can't think what the solution would be now Confused 2000 D2 TD5 - ahhh bless
Post #837513 16th Jun 2020 12:48pm
frenchy
Here’s the response from Fourby to my enquiry
“ Hi David,
Thanks for the email and apologies for the delayed response.
The supplied probe with these Round EGT gauges is actually too short, rather than too long.
It can be made to work but it’s not suitable with our standard boss. If you wanted to use it, you would have to make up your own plate, drill the plate at an angle and insert the probe in the top portion of the plate, to ensure that the tip of the probe reaches the exhaust gases it needs to reach.” 2000 D2 TD5 - ahhh bless
Post #837515 16th Jun 2020 12:56pm
donmacn
That wasn't what I was expecting either. The EGR plate is a good place for a probe though - and as you say avoids the risks and stress of trying to drill and tap elsewhere.
The Madman probe is available at 4x4overlander for £45. I wonder if that would be compatible with the fourby gauge?
If neither 4x4overlander or Fourby can answer that, then perhaps Brian at Madman (in Zambia) might be able to help.
Or just find anither EGT option? I know what you mean about the digital stuff in an older car. I've found that the Madman EMS is a good compromise because it fits in the standard console (more or less) and isn't too garish. But again, it's a more pricey thing. Donald
in the past..
Post #837516 16th Jun 2020 12:57pm
Mo Murphy
Why would they sell you a probe that is too short to use ?
Post #837544 16th Jun 2020 3:43pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Like Donald I’ve just fitted a madman EMS3 and their EGT probe to the EGR blanking plate. Relatively straightforward but as said before you do need to bend it a bit. I put the probe in the plate and then put the plate in a vice and bent it using a ring spanner. I used a piece of wire and cardboard to measure the correct angle before hand.
As said a little nerve wracking but actually ok to do, just take your time.
Simon
Post #837601 16th Jun 2020 6:27pm
frenchy
Am I really the only one who needs an EGT monitor but doesn't want a digital read-out Razz
need inspiration Confused 2000 D2 TD5 - ahhh bless
Post #837667 16th Jun 2020 9:19pm
SteveRat
United Kingdom 1995 Defender 90 300 Tdi CSW Arles Blue
Post #837671 16th Jun 2020 9:33pm
frenchy
looks better than a purely digital version...…..but then they spoil it with the stoopid external temperature readout.
However, on the same ebay page, this little fella popped up.
https://www.ebay.co.uk/itm/2-52mm-7-Color-...0005.m1851
Does Much cheapness = much crapnessI wonder???? Razz 2000 D2 TD5 - ahhh bless
Post #837674 16th Jun 2020 9:52pm
SteveRat
For £20 it might be worth a punt?
Post #837683 16th Jun 2020 10:23pm
frenchy
That's what I was thinking!!! Laughing 2000 D2 TD5 - ahhh bless
Post #837687 16th Jun 2020 10:36pm
