Home > Maintenance & Modifications > Help - SVX Light Questions
darwin1
Hi. I ordered a full SVX light kit (all lights, grill, headlight surrounds, wiring harness) from LR Dealer in UK and shipped it to Central America to put on my 07 Defender. There has not been any SVX's ever imported here, so the the LR Dealer does not know which lights function for what purpose. Hope I can get some help as I don't want them to do it incorrectly.
Obviously, there is the headlight (and then the small bulb inside.....is that an indicator (flasher) or a parking light ?
The top side light with orange-ish tint - is that a parking light?
What is the side bulb on the bottom ?
Any help would be greatly appreciated. Will post pics when the project is finished!
Post #83040 3rd Aug 2011 11:14pm
RobKeay
The little bulb in the headlight is a side light/parking light. The orange ones are your indicators. The small clear ones come on with the main beam like little spot lights.
Hope that helps
Post #83041 4th Aug 2011 12:03am
dgardel
Italy
Re: Help - SVX Light Questions
https://files.me.com/daniele.gardellin/815mfz Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #83077 4th Aug 2011 12:49pm
darwin1
Thank you for the help.
I had the dealership install the lights. They high beam does not appear very bright out of the main headlamp, but the side spot lights come on only with the high beams. Is this correct?
Thanks,
Post #83743 10th Aug 2011 2:08pm
dgardel
Italy
Thanks,
Yes, the spot come ON with main high beams (as std loom) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #83745 10th Aug 2011 2:37pm
have a look at some PIAA extreeme h4 bulbs for the headlights and get a h9 hid kit for the spots
Post #84302 14th Aug 2011 7:06am
