Home > Wheels & Tyres > balancing problem on new wheel/tyre
rossy
I was checking out my new boosts/BFG ATs from Paddocks the other day pending fitting to my 110 which I will be picking up on Wednesday.
I noticed that one of them had not been balanced but there was a strip of weights left in the packaging so I took the wheel to a trusted tyre fitters on my way to work to get it balanced. It took the guy a while to get it mounted properly on the machine and it was calling for 200g of weights to balance which means,he said, that it was unbalancable.
I spoke to Paddocks who will send out another wheel/tyre to us while we are on hols in London in 2 weeks time. Fair play but between then and now I will have travelled about 600 ish miles.
If I put the wheel at the back for now will it cause any problems re suspension/bushings etc if its left on for that many miles, particularly as its so far out of balance or am I worrying over nothing ? Confused
Post #83518 8th Aug 2011 10:55pm
Why didn't the tyre shop break the bead and rotate the tyre 180 deg normally this is just two high spots together , unless there's more to the story,
Generally BFG AT,s in 265 spin up fine 285 can take a bit more time I'd also opt for clip weights as they are further outward will ask for less weight Thumbs Up
Post #83526 9th Aug 2011 4:37am
I would run it on the back axle rather than the front, but I doubt that you'll have any problems with it.
Post #83551 9th Aug 2011 10:33am
rossy
thanks chaps
a guy at work also questioned why they didn't move the tyre around on the rim but I didn't know this at the time. Anyway it will do for now. Cheers
Post #83589 9th Aug 2011 5:14pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
As Ken says ...just rotate the tyre a bit till they get it right ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #83649 9th Aug 2011 9:30pm
AJS4X4
Or ask for another and send it back on complaint. Andy.
www.ajstyres.co.uk 01737 241370
Junction 8 M25 Surrey.
Post #83996 12th Aug 2011 8:16am
rossy
thanks all
in fairness to Paddocks they are going to courier one out and collect the faulty one while we're on hols at the in-laws in London in a weeks time
Post #84015 12th Aug 2011 10:20am
Good shout for paddocks Thumbs Up
Post #84064 12th Aug 2011 2:09pm
