![]() | Home > Technical > Help locating TD5 ECM earthing point |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
The earth will be on the driver's side of the transfer box. When i swapped my loom over in my 02', the original ECM earth was on one of those studs in your image. The new loom had the ECM earth on a ring terminal next to the transfer box.
Hope that helps ? Steve 02' 110 TD5 Double Cab Rebuild Thread |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 ![]() ![]() ![]() |
Many thanks. I’ve solved all my problems by running an additional earth from the internal stud direct to the battery and also cleaning the bulkhead earth behind the expansion bottle. Happy now 😀😀 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
