![]() | Home > Puma (Tdci) > Which swivel pin is correct |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 ![]() ![]() ![]() |
Morning all,
I went ahead and switched my swivel pin bearings and upper swivel pins yesterday . My question is relating to the obvious difference between what came out and what went back in . The two pins are very different , is this okay ? The square shoulder is the the replacement. The reason I’m asking is because I’m getting a bit of swivel play , only perceptible when the wheel is back on and held at 12&6 o’clock ! Many thanks ![]() Click image to enlarge ![]() Click image to enlarge https://www.instagram.com/hustynminepark/ |
I’ve had a good search on google but can’t find the answer to my question, if any of you wise old owls know the answer I’d love to know https://www.instagram.com/hustynminepark/
Dorset smith, thank you .
Why on earth has my auto factor (landy specialists) given me the incorrect ones , they punch my number plate in and lob me a box ! It all came as a kit , will the bearings and cups be matched to the upper swivel pin ? If not can I just drop the original upper swivel pin back in ? Or are these completely different bearings and therefore require a strip back (not at all happy if so!) https://www.instagram.com/hustynminepark/ |
On second thoughts that was a daft question and the bearings are clearly a very different design ! https://www.instagram.com/hustynminepark/
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
The pin TAR100040 is shaped as it is because the inner bearing race is integral with the pin. The others illustrated used a bearing with a conventional inner race.
Thank you both for clearing that up !
So now that I’ve replaced bearings , races and swivel pin do I now need to do it again with the correct part number or is it just a case of one part supersedes the other ? https://www.instagram.com/hustynminepark/ |
If it's all fitted together and you have the right preload and no play then I can see no reason to change it.
Thank you , there’s a small amount of play amounting to a Very gentle knock when pulling/pushing either front wheel . But at the 3 o’clock / 9 o’clock position there’s nothing . Eliminating wheel bearings .
It is not noticeable without the wheel mounted . Swivel preload feels bang on . I’ve reshimmed Several times and have been unable to eliminate this . Looks like I may have to put the correct pins in . Do you think I can leave the bearing races in the swivel or will these be matched as per the wheel bearings ? https://www.instagram.com/hustynminepark/ |
All parts of a bearing should always be replaced together.
Thank you as I thought ! https://www.instagram.com/hustynminepark/
