Home > Maintenance & Modifications > Best location for oil catch can in a 2.2 Puma?
Co1
I’ve had this sat on the shelf for about 2 years now as I can’t find a spot suitable to install it. For those that have them, where have you put em?
Col
Post #824147 8th Apr 2020 5:31pm
It's a 2.4 not a 2.2, I don't know how much difference that makes.
Post #824149 8th Apr 2020 5:34pm
Co1
Thanks. Looks about the same - cramped!
Post #824164 8th Apr 2020 6:32pm
MartinK
and mine Smile
(also 2.4, and installed with help from Blackwolf)...
I'll go and look for the thread in a mo... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #824230 9th Apr 2020 9:51am
MartinK
this thread https://www.defender2.net/forum/topic68596-30.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #824231 9th Apr 2020 9:52am
It is a little tight!
Post #824245 9th Apr 2020 11:15am
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
I fettled some brackets to fit but the raised height of the Provent lid was being pushed down by the bonnet when shut .
I ended up just letting it float without a bracket . It seems perfectly secure and hardly moves with the thick silicone pipes attached .
Added to that there’s no weight to it (unless it’s full of oil !)
I have a drain tap going down to just above the front mud flap with a tap . I can see the oil in the pipe at a quick glance without having to lift the bonnet .
 https://www.instagram.com/hustynminepark/
Post #824246 9th Apr 2020 11:16am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Re: Best location for oil catch can in a 2.2 Puma?
[quote="Co1"]I’ve had this sat on the shelf for about 2 years now as I can’t find a spot suitable to install it. For those that have them, where have you put em?
Mine Thumbs Up
Post #824269 9th Apr 2020 12:54pm
Matt110
Hi guys, slightly different slant to the thread but as you have them fitted.... How much oil do you actually recover? Have you found you're getting 4ml every 12000 miles, or are you getting half a cup?
I can't quite figure out whether or not it's a good idea or not. I know it's almost the first thing Aussie 4x4 owners do this the provent brand, but mixed feelings.
What do you reckon?
Post #832861 23rd May 2020 12:08pm
Bluericky
I’m catching a fair bit , maybe 25ml every 500-700 miles , more so if I’m doing a lot of short runs over a month . https://www.instagram.com/hustynminepark/
Post #832865 23rd May 2020 12:23pm
Avelingporter
Mine I fitted here. Very tight fit for a 2.2!
Post #832904 23rd May 2020 3:05pm
