Home > Technical > Transfer box sensor
claxby
Transfer box sensor
How easy is it to swap the speedo sensor ring and housing over on to the cable type ??
Post #831541 17th May 2020 11:24am
roel
If I understand your question right you want to swap the electronic speed sensor over for a cable and clamp. That;s really easy as it is a straight swap. Take the bolt for the electronic speed sensor out, take the sensor out, put the cable in and put the clamb and bolt on and ready. There is no need to change out other parts. Roel
2003 90 Td5 (2009-now)
Post #831672 17th May 2020 9:29pm
Hufflepuff
I am doing this as well. I have read that the thing the cable clamps into is a bit smaller than the do-dar that the speed sensor plugs into, which would seem a bit odd if that was true. 2005 Td5 90 XS
1989 V8 110 CSW
Post #831682 17th May 2020 10:29pm
Martin
Site Admin
Absolutely not true, the speedo sensor is a straight swap for a cable and vice versa.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #831683 17th May 2020 10:33pm
Hufflepuff
That is what I was hoping someone would say, thank you Martin Smile
You just can't trust these 'other' forums sometimes Smile 2005 Td5 90 XS
1989 V8 110 CSW
Post #831763 18th May 2020 11:52am
roel
I am 100% sure it is a straight swap as I build a 1984 90 with a td5 drive train to be road tax free in the Netherlands. When I almost was finished our friendly goverment changed it to 40 years so then I rebuild it again to a 2001 commercial.
Identify the parts off the different years. Mr. Green Roel
Post #831931 19th May 2020 8:48am
rallysteve
The square drive for the speedo is slightly smaller on vehicles which originally had a 2pin speedo pickup (late discovery 1 V8s and maybe D1 300TDis). We found this out when fitting a TD5 transducer to the discovery transfer box on my V8 project.
Cheers,
Post #831944 19th May 2020 9:39am
Martin
Site Admin
That's down to the speedo drive gear, and you'd typically run a different drive gear in a Defender compared to the Disco anyway due to large tyre circumference on the Defender Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #831951 19th May 2020 10:22am
Hufflepuff
So while we are the subject, and I need to do this at some point in the not too distant future, what do I need to buy here to adapt the existing LT230 which has been rebuilt by Ashcroft, to a Td5 style speedometer?
Speedo Transducer
Do I just buy a YBE100530 unit (the green unit, number '1' in the above diagram), and bolt it on and plug it in? Where is the mythical coloured drive gear, inside the LT230? If so, are these changeable without dismantling the transfer box? 2005 Td5 90 XS
1989 V8 110 CSW
Post #831958 19th May 2020 11:15am
Mo Murphy
The speedo drive gear is in the hole that the cable came out of. Remove the cable, remove the top hat thimble from the hole (if it's been in there for many years it will be easier with hand brake back plate removed to improve access, I use a wood chisel to gently pry out the top hat), withdraw plastic drive gear.
One spanner if all comes apart easily, 2 spanners if the top hat is stuck.
HTH
50 Shades of Pennine Grey
Post #831960 19th May 2020 11:28am
Martin
Site Admin
Doesn't require the box pulling apart, it's basically down inside the hole on the rear housing
You need the correct coloured drive gear to match your tyres, list here:
https://www.defender2.net/forum/topic39592.html?highlight=frc3310
The larger the tyres the fewer the number of teeth needed.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #831963 19th May 2020 11:32am
Hufflepuff
Thank you gentlemen. I had better wait until I have finalised my tyre choice then, which is currently a tricky decision to make Smile My heart and my head are currently in a heated disagreement on size. 2005 Td5 90 XS
1989 V8 110 CSW
Post #831969 19th May 2020 11:57am
roel
My phone gives me the correct speed at least that one is accurate if I change between my 235-85's and my 35"Simexes. Roel
Post #832072 19th May 2020 9:36pm
