![]() | Home > Td5 > Under bonnet lights. Suggestions? |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
Does anyone have suggestions for under bonnet lights? I'm thinking when I open the bonnet the lights will come on. Just wondering if anyone who has done this would share a pic or two?
Also I'd welcome suggestions to where I could pick up the power and where to place a switch. There may be a factory position I could use? Thanks in advance. ![]() ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
I think you can pick 12v ignition live from the heater box.
I have a LED strip under the bonnet but I preferred to run that from a switch in the cab rather than automatic. Insta: @thebenjordan4x4 |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 960 ![]() ![]() ![]() |
Pick up any 12V source under the hood (Yea I am not British). I chose to switch mine With a rocker and marked its location... You could easily use a switch activated by opening the hood. LED all weather cabinet light I had laying around my shop and hardwired it. Its been mounted for several years with no issues.
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Excellent, thanks Guys for the great ideas and pics
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2656 ![]() ![]() ![]() |
Hi MC
I know this is a Jeep channel but it might give you some ideas. The under bonnet install is halfway along the video Good luck &t=75s |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6134 ![]() ![]() ![]() |
Head torch for me if it's dark and I've got to faff about under there. At least you can get light to where you actully want it, instead of just shadows.
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
To keep it Land Roverish how about a couple of these. https://rimmerbros.com/Item--i-DRC2878 My RR classic had one of these fitted as standard but I upgraded it to three all off a plunger switch. The original used the alarm plunger switch. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to ![]() Richard |
