Home > Maintenance & Modifications > Brake hoses
Likeomg
Brake hoses
On second thoughts
Which is the correct kit for a 2.4 90 non abs?
I spoke to good ridge who don’t have a kit for non abs where first four etc I think do?
https://www.goodridge.co.uk/products/car-b...8208569409
Would this be the correct full kit ?
https://www.firstfour.co.uk/goodridge-defe...38617.html
Any help appreciated, don’t have access to my def right now....
Post #831699 18th May 2020 2:23am
The Zee
Just recived a full brake hose kit from : https://pioneer4x4.com/
Joe who makes the hoses up Really knows his stuff,
Sarah looks after the Admin - A really top Team - The kit is EPIC, fit and finish is topnotch - and as customisable as you want.
For my 110 Puma 2.2 2014:
Flexible hoses front - direct to the caliper (No silly bit of hard pipe)
Flexible hoses reat - the two to the tee piece
AND 2 hoses from the Tee to the caliper (the hard pipe that runs along the diff/axle)
plus a load of fittings, clips and bits to make the job tidy
Have nothing but praise for this company. Thumbs Up Zaid-M
www.DefencePhotos.com
Post #831850 18th May 2020 8:36pm
Likeomg
Would this be the silly bit of hard pipe?
Post #831855 18th May 2020 8:47pm
bear100
Just fitted a set of pioneer hoses, great quality and a range of colours if your the colour coordinated type.
Took 3 weeks to arrive if you can wait
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #831856 18th May 2020 8:52pm
The Zee
Probably, I just asked Joe to make up Stainless Flexi hoses that go direct to the caliper!
Soory for being so vauge, but A bit of a Defender newbi, so still learning.
Asked Joe's advice and if it was possible, he said it was easy, then asked if the same was achiveable on the rear calipers, "with Pioneer4x4 anything is" was the reply - the direct to caliper hose is quite popular upgrade Cool Zaid-M
Post #831858 18th May 2020 8:57pm
jst
all my defenders run pipes direct chassis to caliper on front with 45deg banjo, about £20 a pipe from Llama4x4. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #831865 18th May 2020 9:24pm
Likeomg
I found llama 4x4 in some old threads and have been in contact, they will be making me a set up with banjo’s,
Thanks all.
On the rear there’s also a hose from body to axles ? Forgive my pathetic lack of knowledge of the brake system.
Post #831908 19th May 2020 12:03am
landy andy
There is one hose from body to axle without ABS or two hoses with ABS.
Post #831924 19th May 2020 8:26am
