Home > Maintenance & Modifications > Coil springs part numbers?
Page 2 of 2 <12
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
That’s exactly what I’ve just bought for my 1997 110 2 door hardtop. RKB101111 brown/purple
They are fitted to the 110 USW so may be bit harder/higher when not loaded ie: no seats in the back but mine will always have something in the back so not worried! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #831808 18th May 2020 3:33pm
camelman
they will be ok to swap, the brown/purple might sit half an inch higher when unloaded but are actually slightly softer for the initial compression, stiffening up after that.
Post #831809 18th May 2020 3:35pm
db950 wrote:
lrsurplus on eBay have new take off springs listed.
You send them a message with the colour code you require and they’ll get back to you.
I bought new front and rear sets off them a couple of months ago, but......they were £50 a pair then, now they are £125 a pair! Still a saving on new genuine parts though I guess.
https://www.ebay.co.uk/itm/143556653678
Blimey! I also bought a pair of springs for £50 and was very pleased. Darren
Post #831811 18th May 2020 3:41pm
Danny Fireblade
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
Just sent them a message and they have said £125, you must be a clairvoyant Rolling with laughter
Just waiting for pics and if they are new would be rude not to at that price.
Appreciate the offer Darren Thumbs Up
Post #831812 18th May 2020 3:44pm
db950
Not sure why they’ve upped the price so much, probably just realised they could be earning more from them!
I got a set of HD front springs(due to winch and bumper fitted) and a set of rears all for £100 delivered...bargain! 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #831815 18th May 2020 3:48pm
Danny Fireblade
I may be cheeky then and see if they will take £100 instead Whistle
Post #831816 18th May 2020 3:54pm
Danny Fireblade
As you can see I have had a delivery.
I do have a couple of questions though.
I was thinking of some spring isolators for the front. Which ones should I go for?
Also when the new rear springs are side by side, there is a clear difference in height of them? Is this normal and which side does the taller spring go on?
Thanks in advance.
Post #832510 22nd May 2020 1:31am
db950
Great Thumbs Up
As you’ve already bought the shock turret retaining rings I would just go for 2x ANR2938 for the spring isolators, if you hadn’t already got them then RBC100111 Disco front isolators with retaining bolts on could be used.
Brown/purple springs aren’t handed so not sure why yours are different lengths, hopefully they’ll be even once fitted with weight on, I’d fit the taller spring to the driver side.
Rear spring isolators are ANR3060, different design to the fronts though, these are like rubber tube which clip over one of the spring coils. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #832513 22nd May 2020 3:26am
bear100
My both sets turned up yesterday too Very Happy
What’s a spring isolator? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #832522 22nd May 2020 6:08am
db950
The spring isolators are pieces of rubber that sit between the spring and the chassis to stop metal-metal contact, which helps reduce road noise, vibrations etc.
They’re not fitted to Defenders as standard to the front so Discovery ones are used, which can also be used on 90 rears. Some of the newer rear springs do have them on but not all, easy enough to buy and fit them. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #832524 22nd May 2020 6:40am
bear100
Thanks for the info Very Happy
Just ordered a set Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #832527 22nd May 2020 6:53am
For an isolator on the rear of a 110 (with larger diameter springs) I used an Old Man Emu part that's intended for a Toyota (part no.OME80PR10), bought from Devon 4x4:
 Darren
Post #832528 22nd May 2020 7:02am
bear100
Cheers Darren Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #832530 22nd May 2020 7:26am
Danny Fireblade
Thanks Darren Thumbs Up
Post #832557 22nd May 2020 10:19am
Danny Fireblade
db950 wrote:
Great Thumbs Up
Thats great, thanks Thumbs Up
Post #832558 22nd May 2020 10:21am
Page 2 of 2 <12
